Will program for food
ghnat's Avatar
removing front wheel spacer from axle
This is the part I need to remove.
I tried but not much room or available space to pound it off. Seems like it is really pressed on tight. Any removal tips?
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 02-11-2005, 10:37 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Pounding is not the best way to get off the spacer ring. You could damage the spindle.
Since the spacer is pressed onto the spindle, a more effective way is to use some type of puller (like a gear puller) to uniformly draw the spacer off of the spindle.
The picture is a gear puller, but something similar would be what you want to use.
The jaws need to be slim enough at the ends to get the jaws behind the flange of the spacer ring.
Kevin L
'86 Carrera "Larry"
Old 02-11-2005, 10:51 AM
ozz ozz is offline
ozz's Avatar
You might try the local parts store and see if they rent a jaw style puller. There should be enough of a lip on the back side of the spacer to get the jaws to bite and then heat the spacer a bit with a torch (propane is fine) and tighten down on the puller. There is a rubber o-ring behind the spacer so use care when heating it.
sorry - didn't see Kevin's post before I hit submit - he is right on point.
Gary Osborne
Chardon, Ohio
___________
74 911 IROC
98 Panoz GTWC
Old 02-11-2005, 10:55 AM
ghnat's Avatar
Kevin and Gary,
Thanks. That is what I was looking for.
I will get a replacement o-ring because I am betting the original is still on.
So I guess I look for a 2 arm puller, is that the jaw style Gary?
Greg Hnat
98 Jeep Cherokee
Old 02-11-2005, 03:06 PM
Why are you removing the spacer? There is no need to; how much sealing do you think that o-ring has to do if the spacer is on that tightly? Leave it be, otherwise you risk ruining the spacer and the spindle for no good reason. Jim
Old 02-11-2005, 03:12 PM
ghnat's Avatar
Kevin and Gary,
I bought a 2 arm gear puller and removed the front spacers. Thanks mucho. That amount of gunk behind each was scary!
Jim,
My car has high miles and the more stuff I remove the more things I find I need to replace (and I am replacing lots). I want this car perfect when I am done.
Greg Hnat
98 Jeep Cherokee
Old 02-12-2005, 07:01 PM
350HP930's Avatar
Jim is right that there is no need to remove that spacer, no matter how old it is.
Old 02-12-2005, 07:06 PM
ghnat's Avatar
350hp930,
Well, too late. Sorry but they are off.
Greg Hnat
98 Jeep Cherokee
Old 02-12-2005, 07:24 PM
Schleprock
KTL's Avatar
Oh well. If nothing else, Greg learned something new and he's now got a two arm gear puller added to his collection of tools.
Kevin L
'86 Carrera "Larry"
Old 02-14-2005, 06:29 AM
ghnat's Avatar
MMmmmmm tools!
Greg Hnat
98 Jeep Cherokee
Old 02-14-2005, 07:13 AM
