Virginia Rocks!
VaSteve's Avatar
Help Disassembling the Throwout Lever
How do I disassemble this? According to the books photos and catalog, there is supposed to be pin that holds it together. That doesn't appear to be the case with mine.
Do I use some combination of heat, chemicals and brute force applied with the BRH (Big Red Hammer!)? If so, how is it held back on once I'm done?
See the catalog? There's supposed to be a pin in there. Mine doesn't have it.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-13-2005, 06:52 PM
That picture contains parts for both 911 and 930 in the same illustration. The turbo set-up is different from 911. The "extra" parts are ones not for your application.
Old 02-13-2005, 06:56 PM
Clutch Release Lever
VaSteve,
The clutch release cross-shaft should rotate or slide freely from clutch release lever under normal condition. If that thing is stuck as you mentioned, apply some penetrating oil.
He're some of the methods you could use. (1). Push out the shaft using a hammer and a block of wood. Heat application might be needed. (2). Use a gear puller to push the shaft thru. (3). And finally, use a hydraulic press to slide the lever out.
Hope this works......
Old 02-13-2005, 07:26 PM
Irrationally exuberant
ChrisBennet's Avatar
Some have the pin, some don't - at least some SC's and Carrera's for example
Pentrating oil and a 2 arm gear puller should do the trick.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-13-2005, 08:00 PM
Virginia Rocks!
VaSteve's Avatar
The solution was PB Blaster and the Big Red Hammer. It was almost too easy. BRH is becoming my favority $3.99 tool. Works well for certain installs too!
Old 02-14-2005, 05:07 PM
