chrisp's Avatar
Are rotors balanced? Mine have material removed.
I ask because I received new fronts and rears and one of the fronts (haven't looked at the others) has a section machined away from the outer edge. They've removed about .25-.50mm of material along a 2"-3" section of the outer edge of the rotor.
'83 SC
Old 02-14-2005, 09:58 AM
Good ones are, if needed. Mine came directly from Brembo with milling done is some areas to balance them.
Old 02-14-2005, 10:14 AM
Noel's Avatar
Same as mine.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 02-14-2005, 12:07 PM
Still Doin Time
asphaltgambler's Avatar
Yes good ones are when newly manufactured.
Old 02-14-2005, 12:12 PM
