Are rotors balanced? Mine have material removed.
I ask because I received new fronts and rears and one of the fronts (haven't looked at the others) has a section machined away from the outer edge. They've removed about .25-.50mm of material along a 2"-3" section of the outer edge of the rotor.
'83 SC |
Good ones are, if needed. Mine came directly from Brembo with milling done is some areas to balance them.
Same as mine.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Still Doin Time
Yes good ones are when newly manufactured.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
