-   -   Est. 3.4L Twin-Plug hp output? (http://forums.pelicanparts.com/porsche-911-technical-forum/206614-est-3-4l-twin-plug-hp-output.html)
kaisen 02-15-2005 03:46 PM
Also posted in engine rebuilding section:
I have the opportunity to acquire this motor
What kind of power numbers should this combo put out?
"3.4L engine: 930 case/crank/rods, ported and polished factory heads (twin-plug), Crane racing springs, large stainless valves, bored factory NiCom coated cylinders, Webcam high torque racing cams similar to G-80 grind, Ross 11:1 pistons, Electromotive twin-plug crankfire ignition, Weber 46 IDA3C carbs, GHL Motorsports s.s headers 1-3/4" O.D. with GHL s.s 2 in 2 out racing muffler, balanced and blueprinted"
That's all I know for now......any good guesses? 300hp?
What is this engine worth (33K on motor, ZERO miles on re-seal)? $12000?
http://forums.pelicanparts.com/uploa...1108510580.jpg
Thanks,
E
Craig 930 RS 02-15-2005 03:49 PM
Paaaaaaging R. Burns......Mr. R.D. Burns........
dd74 02-15-2005 04:03 PM
kaisen - as I said when you posted this in "engine rebuild" 300 hp, considering the cams, piston c/r and Webers, seems doable.
Steve@Rennsport 02-15-2005 05:20 PM
Kaisen:
A 3.4 in that configuration should make anywhere from 280-340 HP, depending on the quality of the heads, any other internal mods, and how everything was assembled; thats a BIG variable. :) :)
Jcon 02-15-2005 06:03 PM
WOW!
NOH20 02-15-2005 06:23 PM
I have wood!
Shuie 02-15-2005 06:49 PM
should be in the vicinity of 300hp
coloradoporsche 02-15-2005 07:19 PM
If I remember Wilkinson's book correctly (it's currently on loan so I can't check), he calculated 280+HP after adding 15% to the number the dyno came up with which was lower at the wheels...something like 260.
kaisen 02-15-2005 07:24 PM
Thanks, I've followed some of your leads and links and agree that 260-340hp is about right
How about what it's worth?
I know the Electromotive crank-fire ignition set-up is ~ $1500 new
and the 46mm PMO/Weber set-up is ~ $3000 new
Twin Plug, port & polish, and perf. valve job ~ $1500
Ross 98mm pistons + rings ~ $1000
How much is the bore/Nik re-plate?
How much is everything else?
Owner claims to have over $15000 invested
.....so what does that mean it's worth now???
http://forums.pelicanparts.com/uploa...1108524047.jpg
http://forums.pelicanparts.com/uploa...1108524060.jpg
Thanks for any help!
E
kaisen 02-15-2005 07:26 PM
What questions should I ask?
What 'other' relevant mods and assembly procedures should I find out about?
E
Shuie 02-15-2005 07:36 PM
ask for compression & leakdown numbers, hours or miles, and receipts. I would be curious as to what it is being replaced with and why.
kaisen 02-15-2005 07:43 PM
It has 33K miles on it since it was built, all documented, all receipts. Owner claims no track time. The car is definitely a street car, and this engine is still in the car.
I am considering buying the whole car, and just need to 'adjust' $$ for the motor. He still has the original 79K mile motor for the car. For my use/needs I may keep the original and sell the 3.4L.
E
emcon5 02-15-2005 07:44 PM
Ross pistons? Does anyone use those other then Motor Mangler?
The question I would ask is "who built it?"
Tom
kaisen 02-15-2005 07:46 PM
Yes, Motor Meister built the motor in 2001.
What does that mean?
E
Craig 930 RS 02-15-2005 08:01 PM
brrrrroooooooooooowwwwwwwww.........records scratches to an end.
MM rebuild.....
emcon5 02-15-2005 08:01 PM
E
This is your friend: http://forums.pelicanparts.com/images/top_search.gif
Based on their track record, I would be see what the market value is for used webers and electromotive, and offer that. I am guessing ~$2K, $2.5K tops.
Tom
Elombard 02-15-2005 08:06 PM
Craig you are so cryptic :-))
I dont think a motor with those specs would run on the street very well??? Those are really racy cams.
I would not pay $***t for a MM rebuild. DO a search on those monsters.
That motor could be anything 2.2 to ????
350HP930 02-15-2005 08:17 PM
RUN AWAY, RUN AWAY . . .
Kemo 02-15-2005 08:21 PM
Well... with one solex carb, and one weber, a couple of pistons/cyls from a 2.0, another two from a 2.4 and a couple of really nice ones from a VW Beetle using 3.2 rods...hmmm
Paint the valve covers and the fan blue and call it a 3.4. How much more california proven do you need to be? ;)
Carrera3.5L 02-15-2005 08:27 PM
3.4L twin-plug motors running Motronic with the usual upgrades (cams, exhaust, extrude honed plenums, chip) typically make 225-235 whp on a Dynojet. My 3.5L twin-plug motor (also using Motronic) made 239 to the wheels and 246 with some final custom chip tweaking. This can be accomplished with "normal" street compression ratios (9.5-10:1) and street gas (91 or 93 octane). With your higher compression, big carbs, better cams, etc, the numbers above should be easily surpassed.
Steve Weiner gives you a pretty good indication of what the power potential is for the motor in that configuration. If the motor is still in the car and running and you seriously are considering it, pay the $50-$100 for some dyno time and see what it actually makes. The old saying is 1 dyno test is worth 1,000 expert opinions.
I would scrutinize any documents from MM, I personally have never dealt with them (and never will) but I have a friend who worked there for a short while and the stories he tells...
Ralph
