Est. 3.4L Twin-Plug hp output?
Also posted in engine rebuilding section:
I have the opportunity to acquire this motor What kind of power numbers should this combo put out? "3.4L engine: 930 case/crank/rods, ported and polished factory heads (twin-plug), Crane racing springs, large stainless valves, bored factory NiCom coated cylinders, Webcam high torque racing cams similar to G-80 grind, Ross 11:1 pistons, Electromotive twin-plug crankfire ignition, Weber 46 IDA3C carbs, GHL Motorsports s.s headers 1-3/4" O.D. with GHL s.s 2 in 2 out racing muffler, balanced and blueprinted" That's all I know for now......any good guesses? 300hp? What is this engine worth (33K on motor, ZERO miles on re-seal)? $12000? ![]() Thanks, E |
Me like track days
Paaaaaaging R. Burns......Mr. R.D. Burns........
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
drag racing the short bus
kaisen - as I said when you posted this in "engine rebuild" 300 hp, considering the cams, piston c/r and Webers, seems doable.
The Terror of Tiny Town |
Kaisen:
A 3.4 in that configuration should make anywhere from 280-340 HP, depending on the quality of the heads, any other internal mods, and how everything was assembled; thats a BIG variable.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
WOW!
Jeff C 76 912E 2.6L |
I have wood!
2001 Twin Turbo |
Licensed User
should be in the vicinity of 300hp
If I remember Wilkinson's book correctly (it's currently on loan so I can't check), he calculated 280+HP after adding 15% to the number the dyno came up with which was lower at the wheels...something like 260.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
Thanks, I've followed some of your leads and links and agree that 260-340hp is about right
How about what it's worth? I know the Electromotive crank-fire ignition set-up is ~ $1500 new and the 46mm PMO/Weber set-up is ~ $3000 new Twin Plug, port & polish, and perf. valve job ~ $1500 Ross 98mm pistons + rings ~ $1000 How much is the bore/Nik re-plate? How much is everything else? Owner claims to have over $15000 invested .....so what does that mean it's worth now??? Thanks for any help! E |
What questions should I ask?
What 'other' relevant mods and assembly procedures should I find out about? E |
Licensed User
ask for compression & leakdown numbers, hours or miles, and receipts. I would be curious as to what it is being replaced with and why.
It has 33K miles on it since it was built, all documented, all receipts. Owner claims no track time. The car is definitely a street car, and this engine is still in the car.
I am considering buying the whole car, and just need to 'adjust' $$ for the motor. He still has the original 79K mile motor for the car. For my use/needs I may keep the original and sell the 3.4L. E |
Hilbilly Deluxe
Ross pistons? Does anyone use those other then Motor Mangler?
The question I would ask is "who built it?" Tom |
Yes, Motor Meister built the motor in 2001.
What does that mean? E Last edited by kaisen; 02-15-2005 at 07:49 PM.. |
Me like track days
brrrrroooooooooooowwwwwwwww.........records scratches to an end.
MM rebuild.....
Hilbilly Deluxe
Craig you are so cryptic :-))
I dont think a motor with those specs would run on the street very well??? Those are really racy cams. I would not pay $***t for a MM rebuild. DO a search on those monsters. That motor could be anything 2.2 to ????
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Black and Blue
Paint the valve covers and the fan blue and call it a 3.4. How much more california proven do you need to be?
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Doesn't want/need a 3.6L
3.4L twin-plug motors running Motronic with the usual upgrades (cams, exhaust, extrude honed plenums, chip) typically make 225-235 whp on a Dynojet. My 3.5L twin-plug motor (also using Motronic) made 239 to the wheels and 246 with some final custom chip tweaking. This can be accomplished with "normal" street compression ratios (9.5-10:1) and street gas (91 or 93 octane). With your higher compression, big carbs, better cams, etc, the numbers above should be easily surpassed.
Steve Weiner gives you a pretty good indication of what the power potential is for the motor in that configuration. If the motor is still in the car and running and you seriously are considering it, pay the $50-$100 for some dyno time and see what it actually makes. The old saying is 1 dyno test is worth 1,000 expert opinions. I would scrutinize any documents from MM, I personally have never dealt with them (and never will) but I have a friend who worked there for a short while and the stories he tells... Ralph |
