Is the 12 Point Flywheel Removal Tool a specific Porsche Part or...
Can I buy one of these at Sears or something?
Thanks, Ian |
Unregistered
I tried to order one from pelican last year but they were back ordered. I went to kragen auto parts and found a set of three (8mm, 10mm 12mm) for around $15.
So to answer your question, it's not a Porsche tool, they are common triple square key wrenches. |
Air Medal or two
No NAPA will sell ya one or snap on or....
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
I would rather be driving
These are availabe at your local autoparts store. also called a triple-square
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
If you need an 8mm tripple square, I have a HAZET that is NOS, never used. I'll make you a SMOKIN deal on it.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Irrationally exuberant
I think the flywheel triple square (aka "XZN") is 10mm. The cheap ones seemed to be softer than the German ones (Hazet/Stahwille/Heyco) but if you only need to use them a couple of times the cheapies are cheap enough that you can toss them without feeling too bad.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Well, when i needed one I checked every dang auto parts store in town and found nothing. I can tell you one thing though, don't use anything BUT the proper tool! Tried that, screwed stuff up, bought the proper tool in the end anyway.
1967 912 2.7 1977 MGB (bright yellow) 1985 Honda Spree Moped (great for towing rollerbladers) A flute without holes, is not a flute. A donut without a hole, is a Danish. |
Air Medal or two
I think all you need is a 12 pt metric and Napa has them
