Botched shifter coupler bushing replacement
I was trying to remove the pin.... the pic says it all. I was surprised the coupler failed the way it did as I was not applying much pressure.
PP wants $90 for a new one, so much for a cheap busing replacement. ![]()
'02 6GT2 - Weekend toy '04 6GT3 - Track weapon '13 Cayenne GTS - Daily duty '77 Yamaha RD 400 - Wheelie machine |
Driving member
Geez, I did not realize the price had went up so much the couplers. I bought a new one here about 2 years ago and I pretty sure it was 30 something bucks.
Sorry for your misfortune. ![]()
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
If it's any comfort, I did the exact same thing when I went to change my coupler bushings. ***** happens.
1984 Targa |
I think I have a couple of the couplers if you are interested let me know. J R
I read Waynes book and he says specifically not to do it yourself and that the couplers break easily . When I changed mine out I spent the 10 bucks for the machine shop to push it out and put the new one in. Seems like a worthy ten bucks, hopefully someone will read this and learn to aviod it themselves.
Hindsight is 20/20.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
abit off center
I think you need to hold the part with the pin in it, and dont use a press, but to answer your question? you can weld these up just fine.
Craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Oh rats!
Andy |
Yep, I did read Waynes "be carefull, these break" caution but so many had done it, I thought If I went slow, I'd be ok. As you said, Hindsight is 20/20.
Thanks for the offer JR, I'll see if I can talk one of the Denver guys into welding first if not, I'll contact you.
In the shop at Pelican
JB Weld works on these too...
I used it once and it lasted for years |
Craig
When I did the same thing a few years ago, I got one from Dave at Dart. I'm sure he'll have several at the Swap tomorrow. Jess |
Did the exact same thing! I replaced with the same but you may want to consider the coupler from Seine. If I broke mine again I would spring for the Siene option.
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Insert Tag Line HERE.....
Go with the WEVO...
Marc |
Author of "101 Projects"
The dollar has dropped a minimum of 30% since two years ago. Everything is way more expensive now, and still rising! -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Exactly the same happened to me when I used the press to push the pin, I'm pretty sure the 'T' section was a solid piece, so there was no pin to push., so basically it was disposable.
Maybe you had the same coupler as I did... I got the replacement from a wreck and that one looked different, so maybe there are 2 kinds of coupler. Bye J
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde |
The timing of our local annual PCA swap meet was perfect....today. So, I picked up a used one for $20 from Dave at DART and figured I'd give another shot.
I used a large socket to support one side of the coupler so the pin could be pushed through and a small socket on the end of the pin to push it....then, slowly turned the vice. Getting the bushing back in was not easy but after a stint in the freezer and another socket, I was able to press the bushings in. I gave the pin a polish with 600 grit and then pressed it in with my vice. Done !
So it was a $20 learning experience. Not bad!
1984 Targa |
Not trying to be a kill-joy but maybe we should pm people if we are going to recommend another vender that competes against our host...
*2005 Markleeville "Death Ride" 5 Pass Finisher. 129 miles & 15,000 ft. of climbing *California Triple Crown Member (3 Double Centuries in 1 Year) *2003 Giant Carbon Fiber Road bike with Topolino Wheels + a lot of goodies *2000 Torelli road bike - Campagnolo Chorus equiped + a few goodies *1999 Litespeed titanium, full-suspension mountain bike Shimano XT equiped + a lot of goodies. Bill Carcot 1979 911SC - Sold (Searching for a Boxster) 2000 BMW Z3 |
Bill
I certainly respect the fact that Wayne is in the parts business. I also respect that he provides us with this medium. I wouldn't tell anyone that a competitor has an identical part for a buck or two less and that's not what I did here. We had a PCA swap meet this morning at a local used parts vendor and I pointed out to Craig that I had once found the same part he needed there. I am sensitive to the fact that Pelican Parts is a business (a company that I make purchases from) and I really don't feel like a crossed any ethical line here. I welcome the opinion of others if I am wrong on this. Wayne, I meant no offense here. Jess |
Driving member
The key word here is "used" . There is usuallly no problem with used parts. It is new parts that are also offered from our host that pose a problem.
No biggie ![]()
Since I did buy the bushings from PP in January (along with CV boots, valve cover kit, clutch cable, Swepo etc) and since PP does not sell used items, I am not sure I see this as an issue.
If I had botched #2, I would have bought a new one from PP.
