IAN IAN is offline
Is the 12 Point Flywheel Removal Tool a specific Porsche Part or...
Can I buy one of these at Sears or something?
Thanks,
Ian
Old 02-20-2005, 12:57 PM
Unregistered
sammyg2's Avatar
I tried to order one from pelican last year but they were back ordered. I went to kragen auto parts and found a set of three (8mm, 10mm 12mm) for around $15.
So to answer your question, it's not a Porsche tool, they are common triple square key wrenches.
Old 02-20-2005, 01:06 PM
Air Medal or two
afterburn 549's Avatar
No NAPA will sell ya one or snap on or....
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 02-20-2005, 01:51 PM
I would rather be driving
jpnovak's Avatar
These are availabe at your local autoparts store. also called a triple-square
Old 02-20-2005, 02:00 PM
304065's Avatar
If you need an 8mm tripple square, I have a HAZET that is NOS, never used. I'll make you a SMOKIN deal on it.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-20-2005, 02:05 PM
Irrationally exuberant
ChrisBennet's Avatar
I think the flywheel triple square (aka "XZN") is 10mm. The cheap ones seemed to be softer than the German ones (Hazet/Stahwille/Heyco) but if you only need to use them a couple of times the cheapies are cheap enough that you can toss them without feeling too bad.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-20-2005, 03:18 PM
slater's Avatar
Well, when i needed one I checked every dang auto parts store in town and found nothing. I can tell you one thing though, don't use anything BUT the proper tool! Tried that, screwed stuff up, bought the proper tool in the end anyway.
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 02-21-2005, 12:09 AM
Air Medal or two
I think all you need is a 12 pt metric and Napa has them
Old 02-21-2005, 06:36 AM
