krk krk is offline
Let's talk turbo -- is it time to upgrade?
Folks,
The actual turbo on my '76 930 has announced its retirement.
The question is what to do. I can spend some cash-o-la on a rebuild of the original turbo, or go with something new (a k27 variant? which one?)
The engine is at 50K, which is about 10K on a rebuild that moved it to 3.2L (7.6 compression, iirc???) Everything else is stock. (It's about to get an oil cooler up grade -- guess what the 40K failure was....)
Anyway, I'm looking for BTDT or opinions on newer turbos, and pointers to conversion info if you have 'em!
'Course, I've attached a pic : -- well, really, I just like posting pics of my car -- heh.
Thx for any pointers y'all might have!
kim.
Old 02-21-2005, 11:19 PM
ZAMIRZ's Avatar
I can't help you on your questions, but if that's your house with the 914 parked in the driveway, I like your style.
Amir
'83 911SC
Old 02-21-2005, 11:29 PM
biosurfer1's Avatar
i agree...and 911 and 914, much better taste than a volvo and an old acura(no offense)
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 02-21-2005, 11:31 PM
krk krk is offline
*chuckle*
Yeh, the house is an eichler -- I appear to have a "cult issue". P-cars (the /6'er is mine) and eichlers. I tell my p-car junkies that an eichler is a p-car that doesn't have wheels, and I tell my eichler junkies that p-cars are are eichlers that move. Each of them has a design theme about them, and to some degree, there is a "love 'em or hate 'em" thing about them as well. (there are some great p-cars in the neighborhood tho -- just last week I heard about a 74 carrera w/16Kmiles on it -- I gotta get out more!
(the old acura has been replaced by a hybrid of some sort -- they actually are pretty cool neighbors)
kim.
76 turbo carrera, Silver (totally operational)
70 914/6, signal orange (coming to a garage near me)
Old 02-21-2005, 11:45 PM
krk krk is offline
The least I can do is add more pics -- heh.
kim.
Old 02-22-2005, 12:33 AM
I am by FAR not the most qualified guy to instruct you, but somebody needs to give you some direction so here goes. I recommend the K27 7200, it is a great all around upgrade and the best compromise in my opinion. It spools fast enough so that the car can be tracked on the weekends but also keeps enough of that big boost feeling that you bought the car for anyway. They are quite reasonable (as turbos go) and quite proven as I have seen TONS of them on 930s.
Of course, you do know that you are at the edge of the slippery slope, don't you??? Every 930 owner gets there at some point!!! You are NOT far from modern sportscar performance, if you want it! If I were you I'd consider with the turbo upgrade, an aftermarket intercooler (you'd have to replace your tail to fit it, but it is worth it in my opinioin), 1.0 boost spring, and an aftermarket exhaust (with dual pipes so you can hear the wastgate dump under full throttle). While not exactly cheap, that route would turn your car into a new animal.
Heh heh heh, if you are really quiet you can hear the dark side calling!!!
Best of luck
TT
p.s. I LOVE the house! Architecture is one of my other passions as well, any more pics of the eichler???
1986 930 ~ 355 rwhp and 391 rwtq
Old 02-22-2005, 06:50 AM
The thing I love about architecture, is that you learn something new every day.
http://www.eichlersocal.com/NewsandArticles/exhibit.htm
Somehow this name is not ringing a bell from my 20th century architecture class...........been 20 years though.
Nice cars, but you know that already.
Old 02-22-2005, 07:56 AM
I put a k27 7200 on my 88 turbo cab at it helped with both lag and HP. I assume your car doesn't have an intercooler so I'm not sure if this upgrade would be a good idea in your case. Call or go to Imagineauto.com for expert advice. I believe the owner is also a tech advisor for PCNA.
Old 02-22-2005, 09:00 AM
krk krk is offline
[QUOTE]Originally posted by Texas Turbo
[\QUOTE]
heh -- that's how it grew to a 3.2! Thx for the comments. I'm not quite ready to lose the early tail -- as you might guess, I've debated this a lot in my head. I do have some restrictions (no pun intended) regarding CA smog checks which are now permanently in place for '76 and newer (ugh) -- which has probably saved me a lot of money ;-).
The k27 7200 has been recommended by several -- I think I recall that it's not a bolt on change -- but I haven't found a pointer yet.
Best of luck
TT
It's a restoration project -- there are tons of pics of really interesting things like doorknobs and such But this one shows the front of the house pretty well. (if you look closely, you can see the atrium in the center of the house -- the inside walls are glass, and the back wall to the back yard is glass as well)
kim.
Old 02-22-2005, 10:14 AM
krk krk is offline
Eichler was the builder. The houses were built roughly between 1960 and 1970, mostly in the Bay area, with some in LA and a couple, strangely enough, some scattered in NY.
The architecture firms were "Jones and Emmons", "Ashen & Allen", or Claude Oakland. The post and beam designs, with tons of glass, took a lot from more famous architects like Richard Neutra ("The Machine in the Garden" is a marvellous example) There were a set of case study houses sponsored by (iirc) the "art & architecture" magazine (late 50's and early 60's -- very cool designs -- often photographed by Julius Shulman. (I know -- "too much information"! -- I can post more tho -- heh)
kim.
Old 02-22-2005, 10:20 AM
krk krk is offline
Thx for the BTDT -- it's definitely helpful. And I think talking to imagineauto is also a great suggestion!
There is no intercooler (yet) -- as I mentioned, I'm quite happy with the early tail so I'm of mixed minds on making the change to the tea tray.
kim.
Old 02-22-2005, 10:22 AM
Yeah, just call Stephen at Imagine. He is the guru when it comes to these cars, I bought almost everything from him. Great guy to work with and VERY knowledgeable.
TT
Old 02-22-2005, 10:44 AM
krk krk is offline
Brief update: spoke with Scott at Imagineauto today. His feeling was that the K27 7200 would be an upgrade without regard to the presence of an intercooler -- but he wanted to verify with Stephen -- so I'll hear back from them soon (apparently )
Thx again for the comments!
kim.
Old 02-22-2005, 10:19 PM
The K27-7200 is a good way to go. I have a full bay intercooler for sale for that car if you are interested. Send me an e-mail if you want to.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 02-23-2005, 04:53 AM
Forced Induction Junkie
WERK I's Avatar
It will take some creative plumbing to fit an IC under the decklid of a '76 turbo. IMHO, the early turbo decklids are the nicest of all the tails Porsche has done. There might be some threads on the subject with either Rennlist or Pelican from people who have been able to retain the deck and still implement an IC. Good luck!! Beautiful car(s), btw.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-23-2005, 05:28 AM
beamonk's Avatar
Send a message via AIM to beamonk
If you are looking for just the turbo and have someone else replace it call Udo at MJM auto in Buhl Al. 205-339-0616. Tell him John sent ya.
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 02-23-2005, 05:30 AM
