newb.
Idiot Questions, first round.
ok, where do I find the original paint code on my freshly repainted, recently obtained, incorrect colored Carrera 3.0?
Anyone know available colors for 1977? This loooks like it WAS a silver, maybe with a greenish tint or slight yellow tint? Also, anyone know if the 964 cam upgrade is sensible on the Carrera 3L (like the SC?) ok, that's enough idiocy from a front-engine wasser-pumper for now!
keith '75 RS/RSR-look | '73 CB750 | '70 TD250B r gruppe #436 |
The paint code is on the passenger side fender, in luggage compartment.No experience with the cams, but a lot of people seem to be running them. Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Open the drivers door and look at the plate on the frame. If you are sitting in the seat, open the door, and look at the frame, as if looking at the front tire. You'll see the plate on the door frame. The paint code is on the bottom portion.
Jim
Jim Dean LL.B. - London, Ont, Canada. 1969 911T "Blood Orange" Euro (Brought over from Germany in 86) Engine and brake system rebuilds 2006 & 2007 "Oversteer scares passengers, understeer scares drivers." |
Air Medal or two
964s will "turn on at top end a little mre then sc will. some like it...you have to ck your clearence real carefull
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
newb.
from the label in front of doorjamb:
KUNSTHARZLACK 266-9-3 ??
Looks like it might be this
266-9-3 Y8Y8 Ice Green Metallic ![]() Found this reference in relation to 76 model year. I'll double check my Porsche bibles when I get home. Jim
Jim Dean LL.B. - London, Ont, Canada. 1969 911T "Blood Orange" Euro (Brought over from Germany in 86) Engine and brake system rebuilds 2006 & 2007 "Oversteer scares passengers, understeer scares drivers." Last edited by copper; 03-01-2005 at 10:21 PM.. |
Peter Morgan shows Ice Green Metallic (266 Silver Green), a special order body color beginning in 1976.
1984 RoW Cabriolet - GP White |
Okay, Red Book shows it as a 1974-77 model Special Order color of Ice Green Metallic, as we've stated above.
However, this specific color, according to other sources, was not available on these models until 1976, so it will only appear on factory correct 76 and 77 models. It was not continued in 1978 and on. Jim
Re: Idiot Questions, first round.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Senior Member
Ron is correct. I am madly in love with my 20/21 cams. My SC makes 174 lb/ft of torque at the wheels, which is about 205 at the crank, which is pretty good for a motor that is specified at 174 lb/ft at the crank. But I do not thing these cams increased peak hp. I think they made the torque curve look like your kitchen table. The power band is broad and useful everywhere. The dyno guy stared at the torque curve printout and insisted that it is a V8 curve. My job site has a parking garage with spiral ramps. One turn per floor. I crawl up those spiral ramps in second gear (this avoids exhaust resonance) at 1000 to 1200 rpm, and power is smooth and strong even there. I'll stop my rant here, but yeah.....it's fair to say I like these cams. They are also sometimes referred to as "964+" cams.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I sent my 3.0 cams to John Dougherty to weld and grind to 964 specs. They are awesome. I had Webcam 20/21 in my Carrera and I'm pretty sure the SC pulls a lot stringer, though that may have to do with the SSI's too.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
RETIRED
I did the 964 cams on my 3.0 powered 914/6....BIG improvement....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thread Tools | |
Rate This Thread | |
