OK, I can try that, but one other question regarding a wire I asked about earlier. It's the other wire (not the CD box wire), that comes from a pole connector into the coil #15. This wire comes from a pole connector, then spits into two double connectors into the breather housing cover,( back behind and under the air box. ).
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
I put a test light to the #15 on the coil with the ignition on (VW test) and got nothing. I assume this is because the current goes to the CD box, where I am getting full current from the battery, tested out ok.
So if the current comes from the CD box, I am trying to figure out why the additional wire at #15 at the coil. From the Haynes manual it looks like this wire goes to something called a WECO connector. Haynes gives the coil specifications page 87, with "should be" resistances under CDS paragraph 9. My spare coil, Bosch, may not be right for CDS, it has a different number on the bottom than the original. The only coil I have used is the original which is now broken, .................. so is there a selection of coils with correct resistances best for a 1969 E with a CD box?
Thread Tools | |
Rate This Thread | |
