Ok what is the best swaybar for the money?
TRG - 22.9mm , 23.8mm , 24.5mm - $525.00 Smart Racing - 20mm , 23mm , 27mm , 31mm - $675.00 Elephant Racing - 22mm - $475.00 Tarett Engineering 22mm - $475.00 Hmmmm. Elepahant and Tarett are same product... _____________________________________________ Anyone want to guess what swaybar and rate would be best for my 911 Air Ride suspension project?? Racers Group: ![]() Smart Racing: ![]() Elephant Racing: ![]() Tarett Engineering:
Thanks Todd I drank what? = Party out of bounds - PriceLESS - BudWIZER "Boy Im gonna burn you a new one! - A new what officer?" = night in jail 993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
I'd also like to know if Tarett and Elephant are one in the same? They seem to have the same products at the same price.
Also add Kanna Motorsports to the list $490.00.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com Last edited by armandodiaz; 03-04-2005 at 08:32 AM.. |
Anyone?? I need to buy one!!
Call Smart or TRG and ask em what the extra money gets you over the competition. The TRG looks a lot like the ER but the Smart is much different looking. There might be a reason.
Edit I was looking at the wrong Smart racing bar, the all look very similar. I cant help you there but I would still call.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
SmartRacing lets you change out bars larger or smaller and also front to back. Once you get the hardware, they are around $130/each. Buy good ones, it only hurts once.
What do you get out of a larger diameter ( stiffer ) sway:
Less roll I know, but what else? What are the trade offs??
The more I look at it, the more it looks like something I could build myself...
CM tube CM hex stock Flange mount ball bearings Pitman Arms Rod ends Jamnuts Threaded tube Bolts & nuts .
Warren Hall Student
Elephant sells the Tarret swaybars. Chucks' (Elephants) main product that he designed is the bushings for the control arms and swing plates. His are the best bushings out there bar none in my opinion. He also makes a strut brace.
You could build your own sway bars but it would take some trial and error without a machine to measure the spring rate of the bar. If you want a low cost alternative then you could get the Weltmeister setup. They work but they aren't as nice as these products. They sometimes bind and make noises. The Tarret seams like the best bang for the buck out there and Pelican sells them so it's a good way to go.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
What about Tarret vs. the Smart Racing bars?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I guess the Kanna bars are out of the question?
They seem to use alot of the same features of smart bars.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
SRP has a better geometry, look and you will see the bar drop link attaches to the A arm in a very different manner
Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
looks like the TRG bar may mount the same as the SRP
Ok guys - I am ordering one of these today.
ANY MORE INPUT??
Porsche Junky
I'm using the TRG setup front and rear....no complaints....but I agree the Smart setup looks very nice......
1986 930 RUF equipped |
mede8er - What size TRG sway??
I have been thinking the same thing so no direct experience.
However, SRP advertises "correct geometry" so that the drop link/bar won't bind. I did witness a friend's 911 where the TRG drop link bind & snap on track. Haven't heard anyone broke SRP. But then that's only 1 datapoint.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Bind at what point?
Snap at what point?
Todd, not sure about where it bind. But the drop link essentially snapped @ one of the ends so an indication that it came to a bind at some point.
