| Registered Join Date: Jun 2001 Location: Brea,Ca
				 |  another jack stand placement question
			Im am looking to pull off my front wheels on my 74 911 for refinishing. I have read several threads on jack stand placement for the front end. Is is safe to place the jack stands on the track control arms just behind the tow hooks? The car will be on stands at least a week with a full tank of gas.
|  03-04-2005, 07:38 AM |
| Registered |
			The front torsion bar mounting points is a good spot.  Very solid.
				__________________ Walt 82SC 3.0 81SC 3.6 | ||
|  03-04-2005, 02:17 PM |
			Walt, is that the same lacation as the track control arms I'm referring to?
|  03-04-2005, 02:19 PM |
| Registered Join Date: May 2004
			Tom, If you have Wayne's book it shows the front torsion bar cover placement for jacking up your car. One of the first projects. Basically, you will see the "half rounded" cover with two bolt heads showing. Your jack and the stands "cradle" this torsion bar cover nicely. Seemed very solid when I used these last weekend, I gave my car a good shaking to be sure. I also put the wheels under the pan below the doors and run some 2x4s accross the whole pan to the other wheel as a backup plan. I get nervous under a car  -Chris
				__________________ 1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... | ||
|  03-04-2005, 02:23 PM |
			Walt, Yes, I have Wayne's book I'll crack it open to see the picture... Thanks for responding! | ||
|  03-04-2005, 02:27 PM |
			Good job Walt    -Chris
|  03-04-2005, 03:20 PM |
| Registered Join Date: May 2002 Location: Portland, Oregon
			My preferred front location:  My preferred rear location:
				__________________ Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic | ||
|  03-04-2005, 07:06 PM |
