| Registered |
				Help on selecting T bar size rear
			I am rebuilding the rear suspension soon with new bushings and lowering to euro height on the 87 Carerra. I have 21mm bars in the front with new bushings that I did last fall. Do I want to upgrade the rear T bars also? What size would I need for mostly street and some auto-x? The reason I am concerned is the lower ride height and the horrible roads here in Michigan. Thanks for the help!
				__________________ 87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra | ||
|  03-07-2005, 04:33 AM |
| Registered Join Date: Aug 2002 Location: Galivants Ferry, SC
			Do a search......much said on this topic and there is no "one" right answer.  If you aleady have 21 front and are "OK" with that...go "at least" 27 in the rear....but consider 28 or 29, depending on you tolerance for bad roads. Wil
				__________________ Wil Ferch 85 Carrera ( gone, but not forgotten ) | ||
|  03-07-2005, 05:10 AM |
| Bandwidth AbUser Join Date: Nov 2001 Location: SoCal
			I second Wil's excellent suggestion...27mm rears.  Bombed out roads will make it challenging to tolerate much stiffer.
				__________________ Jim R. | ||
|  03-07-2005, 05:43 AM |
| Schleprock Join Date: Sep 2000 Location: Frankfort IL USA
			29 isn't going to kill you.  I think the standard response for the G50 is either 21/28 or 22/29. I have 22/29 with Bilsteins (HD frt., Sport rear) and it's not harsh at all. On nasty roads it'll beat you up some. But nasty roads beat me up even more so with the stock stuff. Seemed worse with the original setup because the shocks, bushings were worn and the springs were softer. Bumps are now a solid !THUD! instead of a nasty !WHACK! that reverberated throughout the entire car with the stock setup. Whatever you choose, you had best upgrade the rears to maintain some sort of balance.
				__________________ Kevin L '86 Carrera "Larry" | ||
|  03-07-2005, 05:51 AM |
