Somewhere in the Midwest
Warren/Grady/GeorgeK anyone..explain this 934/935 CDI box
Someone posted an ad in the classifieds...interesting. Looks like a potentiometer to retard or advance ignition...is that right?
Please enlighten this idiot ![]()
Souk,
Per Paul Frere,935 distributors had no centrifugal advance mechanism ... where you dialed the dist. body to, and tightened the nut -- that's it!!! Although I have no experience with 935s -- so don't take this as Gospel ... it would be very easy to build a variable delay stage either ahead of, or after the Schmitt Trigger of the 6-pin CDI unit. All it could do would delay the spark for a retard effect, so the distributor body adjustment would have to be dialed-in and bolted down with slightly more advance than normally needed ... and then the dial on the CDI box could be used to set and mark known advance settings. Makes a lot of sense when you think how hard on the skin of the hands it must have been to loosen and tighten the hold-down nut for the dual-plug distributor of a 935 engine! Asbestos octopus or gloves would have been handy ... just like in the days of the 550 Spyder!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
This is a Rev Limiter on a Bosch Motorsport CD box. They moved a bit in use in 935's and were a bit finicky.
Best regards |
Hilbilly Deluxe
That almost looks like a aircraft style circuit breaker.
Tom |
