headers ?? pro and con
all;
i am considering headers for a hot street engine. 2.4 - 2.7L (haven't decided yet) & webers. heat to the interior is not an issue. 1 1/2" ?? 1 3/4" ?? Bursch ? is there such a thing as OEM ? comments on the units in the pic, please. ('73 RS ?) all help greatly appreciated.
best
jerry
Old 03-08-2005, 01:14 PM
echrisconnor's Avatar
Pros: Lightweight, more power, cool look & sound.
Cons: No heat. Harder to confuse with a cat & therefore more likely to get you red-flagged in emissions testing. Also, headers may pass more heat on to the engine, so you may see small increases in operating temperatures when not at speed.
Also, what you've got there just look like a standard set of HEs with the boxes cut off. As a header, they're about as good as it gets. SSIs are, of couse, the best. Bursch ones I hear rust out but may be good for the money. You probably want to just go with the stock size (I believe 1 5/8), anything bigger and you'll kill your low-end torque.
How hot will this engine be?
'76 911 Carrera 3.0
Old 03-08-2005, 01:18 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
1 5/8 OD Headers.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 03-08-2005, 01:32 PM
Bill Verburg's Avatar
For a 2.7 hot or not you can't do much better than SSIs their primaries are 1 1/2" OD( 1 3/8" ID ), wt ~24#s,
Mild steel like Bursch uses will quickly corrode.
Bill Verburg
Old 03-08-2005, 01:36 PM
I am running 1 1/2 OD on my 2.0L race Motor. Wont 1 1/2 on a 2.7 motor choke it down too much?
Most of the guys racing with us are using 1 1/2 on the 2.0L race motors and 1 5/8 on 2.4 above.
Mark Scott
Vintage 911 Racer
Old 03-08-2005, 01:59 PM
No, it's better to be a tad small than big, as w/ brakes smaller is advantageous, the smallest diameter pipe that will pass the gas at peak rpm and load is what is wanted, there is more to it than that but that is a good starting point, other things like primary length, transitions, collector design and size all enter into the equation. Most of us need to buy off the shelf anyway.
When you start getting into race 3.2s 1 5/8 OD is starting to get useful.
Bill Verburg
Old 03-08-2005, 02:55 PM
Gents;
thank you all for the feedback. i really appreciate it. after 25 years of 4-cylinder bliss i am pretty new to 911's, but learning fast thanks to guys like you and this board. is it my imagination or are the units in the above pic NOT the same as stock units for the same vintage ? they appear as though each tube is of the same (approximate) length, a concept i understand.
comments ?
thanks again
best
jerry
Unclear on the concept ? Let's see if I can help.
1) You are NOT in the "fast lane" and...
2) You are NOT going "fast enough".
**News Flash**
You're in the Passing Lane. Any questions ?
Old 03-08-2005, 04:51 PM
Administrator
Jack Olsen's Avatar
Early cars came with near-equal-length headers. And as a bonus, you got heater boxes around them (handy for foggy windshields).
SSI's are hard to beat. And as a bonus, you get heater boxes with them (handy for foggy windshields).
Old 03-08-2005, 06:08 PM
jwmc1's Avatar
I am running 1 1/2" on mine....I am running on the street, if you run on the track with a racing muffler you can get away with bigger...just my $0.02
John
Old 03-08-2005, 06:39 PM
randywebb's Avatar
Right, not more power with headers since the SSIs _are_ headers. But true headers will be a bit lighter in wt. So if you live in SoCal and don't travel there is a benefit.
Somebody should make these things out of Ti like on the new vette's...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-08-2005, 07:26 PM
so... the units in the pic are the same as the ones on my '69 (minus the heater boxes) ?
thanks again all!
best
jerry
Old 03-09-2005, 09:53 AM
Yup. They look like a pre '74 heat exchanger with no boxes. This should be the same as what you've got on your '69 less the boxes.
'76 911 Carrera 3.0
Old 03-09-2005, 09:57 AM
Now in 993 land ...
aigel's Avatar
Unless you never go out in the rainly season (street or track) you DO need heat in the Bay Area. I just did an event at Sears and it was raining on and off. It would have been impossible to keep my windshield clear without heat with both windows down. It also would have been uncomfortably cold.
Stock HE or SSI are my vote.
George
81 SC (sold)
Old 03-09-2005, 09:58 AM
Nobody
bob tilton's Avatar
help me understand...let's say i remove the heater boxes from the stock heat exchangers on my old 2.2 longblock. this would be an inexpensive alternative to buying headers?
Bob Tilton
www.werkcrew.com
Old 03-09-2005, 11:18 AM
klaucke's Avatar
Bob, I suppose it would be an inexpensive alternative to buying "headers," but what will you gain by removing the heat exchanger boxes from the primary tubes? In theory, SSI's are headers to begin with, as are early style heat exchangers. When I think "exhaust header" it's just the part of the exhaust which bolts to the exhaust ports ("tail" pipe is at the other end of the exhaust) . There are cast iron headers, like american V8 trucks use, and there are tubular headers like high performance american V8's use. I would still call what an SC or Carrera has a "header," it's just that it is not a high performance, tubular header like an SSI is. Of course, for a certain application there might be a different brand/style of header that is better than an SSI header. If you look inside an SSI, it looks quite similar to the "header" pictured at the top of this thread. I think a lot of people use the term "header" to mean high performance (i.e. tubular) header, where as I have always known the term in a more broad sense.
Old 03-09-2005, 11:27 AM
Yes, thought the SSIs are going to be more nearly equal length.
Bill Verburg
Old 03-09-2005, 12:24 PM
Nobody
bob tilton's Avatar
thanks guys. running SSIs on my new 2.7 but still have my 2.2 hanging out in the garage. the hearter boxes on the stock HEs are starting to rust out but the pipes are functional. may be a good solution for converting to headers with a little work and ceramic coating.
Bob Tilton
www.werkcrew.com
Old 03-09-2005, 12:30 PM
If you're looking for an immediate, low cost solution, you've got it sitting in your garage then. Sand blast, paint, and you're in business.
'76 911 Carrera 3.0
Old 03-09-2005, 12:48 PM
Now in 993 land ...
aigel's Avatar
Okay, here is the nomenclature:
All 911s have headers. They just happened to be covered by metal to make them also 'Heat Exchangers'. The early cars have better headers, because they tried to keep them equal lenght and also have a sane routing, not having to go through a single cat.
The "opposite" of headers are cast iron manifolds, that mostly do not have individual runners. This is something you find on non P cars a lot. Here is a lot of power to be found if you change these manifolds to headers.
As usual, Porsche already found a lot of power for us and it is hard to top off the factory. This may not be true for smog era cars, but it certainly is true for the early cars that had close to equal length tubing and good routing on the exhaust.
George
81 SC (sold)
Old 03-09-2005, 01:36 PM
analogmike's Avatar
HI,
My stock 2.7RS engine (S cams, MFI, etc) was dyno'd with 1.5" SSIs and then with 1 5/8" RSR style headers.
The 1 5/8" do have more HP and rae stronger above 6K but very poor at lower RPMs. Not good for autox or street.
Regards, Mike. AnalogMike at aol dot com
'73 911RS Clone, '08 911 GT3 cup,'04 Touareg, '16 Audi S3, '01 Viper GTS,'05 Bentley CGT, '50 Crosley Hot shot
my racing pages - http://www.analogman.com/911
~^v^~ aNaLoG.MaN ~^v^~ guitar effects LLC www.analogman.com
Old 03-09-2005, 02:54 PM
