Originally posted by john70t
Science will prove most....
great thinking John.
So you'll have the motivation to do a voltage drop test on the circuit Before & After the 3w install asap ?
I want them anyway. I'll re-wire if I have to. i already have a 4amp re-set cb in their already.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-14-2005, 03:15 PM
jyl jyl is online now
jyl's Avatar
I'd like to buy those bulbs as well.
I am also interested in what wiring/switches I will want to upgrade.
I am not particularly concerned about how the additional brightness measures on a lightmeter. If you do measure the brightness, definitely have the bulb illuminating a larger and evenly lit surface, and meter off that surface, or it will be hard to get a consistent measurement. be sure the camera is metering off just the lit surface, not the rest of the dash, a spot meter will be helpful. But in the end, 3v is going to be more light than 2v, so who cares if it is 1/2 f-stop or 1/3 f-stop better? Note that the margin of error in even very expensive spot meters is 1/3 f-stop.
Old 03-14-2005, 03:18 PM
I was doing some calculations in regard to the wiring harness for the instrument lights. (anyone know what gauge wire is in there???) Anyway, with 10 -2 watt bulbs in use at 13 volts you are drawing 1.53 amps. Same voltage with 10 -3 watt bulbs and the draw is 2.3 amps. 24 gauge wire is rated at 3.5 amps. 22 awg rated at 7. I doubt this is going to be an issue.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 03-15-2005, 12:14 PM
Warren wrote on the 1st page..."The instrument illumination bulb Black/Blue wiring is 0.5 mm^2, or slightly smaller than 20 ga on the AWG chart".
I have an Email into the gentleman who procured the bulbs asking for the distributor/manufacturer contact info.
Warren & Ron, may you rest in Peace.
Old 03-15-2005, 12:35 PM
coloradoporsche's Avatar
What about heat dissipation? An incandescent bulb using 50% more power that will be on for extended peroiods of time could get hotter than the designers intended.
I'm holding out for the LED solution
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 03-15-2005, 12:40 PM
I'm looking at an automotive wiring chart and it appears that 13 feet of 20 awg is good for 8 amps!
http://www.industryfigure.com/berkeley/jeep/electrical/autowiring.htm
The led's ( I haven't tried mine yet ) might work better in the foglight switch and rear window defroster switch..at least the light is pointing in the right direction.
Peace, Ron
www.ronorlando.net
Old 03-15-2005, 12:45 PM
I thought of this as well....but I'm not buying a thermometer.
Old 03-15-2005, 12:47 PM
19 years and 17k posts...
azasadny's Avatar
Count me in!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 03-15-2005, 12:53 PM
Heat, I wouldn't lose any sleep over that, metal bulb sockets, metal cased gauges..I once measured the heated air temperature coming from the heat exchangers into the cabin..at the defrost vents I pinned the thermometer a 250 degrees! can you say paper ducts!!!
Peace, Ron
www.ronorlando.net
Old 03-15-2005, 12:59 PM
Sports Purpose 911 Driver
mjshira's Avatar
count me in
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 03-15-2005, 05:25 PM
Unregistered
sammyg2's Avatar
Ignore the naysayers, I want some bulbs. i will take care of the electrical needs, just sell me some bulbs! Please!
Old 03-15-2005, 06:57 PM
Gasoline User
1974carrera's Avatar
Count me in too!
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 03-15-2005, 07:56 PM
Banned but not out, yet..
RSBob's Avatar
Better increase the order, I'm interested too.
Old 03-15-2005, 09:39 PM
don't forget... lol
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-15-2005, 10:06 PM
Old 03-31-2005, 12:40 PM
See my test thread for the less than stellar results. The 3 watters are brighter but not by much. I have a couple more tricks up my sleeve. I will beat this.
Old 03-31-2005, 12:52 PM
Senior Member
Rick,
Add me to the list. Was on the first list but who knows where it is.
A question... what kind of light meter is your Fathers??? Does it start with a "L"???
JoeA
Old 03-31-2005, 01:35 PM
Joe, I'll check and let you know.
Old 03-31-2005, 02:01 PM
Steve W's Avatar
I once bought some gauge bulbs from Performance Products and mistakenly given 6 volt bulbs used for 356s?. When I installed them, those suckers were so bright, there were definite bright spots and uneveness from where the bulbs were replaced in relation to the original bulbs. They didn't last for more than about an hour before burning out - which was a good thing because I thought they were too bright and I didn't like it.
Old 03-31-2005, 06:39 PM
scottb's Avatar
See what happens when you buy from "the other guys?"
1984 Targa
Old 03-31-2005, 07:36 PM
