Almost ready to install BAE kit...
just got back for the welders..
he just COULDENT get my muffler to fit... flow master 50 series. so i will be running the exhaust right off the turbo.. im talking about a 1.5 feet of straight pipe coming off... till i can figure out what to do next. how loud is it going to be? this friday i will slap everything together and see if it runs.. wish me luck!
SWB |
all the plumbing is done... well at least up top
i wasent sure where i was going to put the oil tank vent line...if thats what you call it.. i sure dont want the oil tank under boost so i attached to a un-used hole on the right side of the airbox.... before the sensor plate... thats ok right? the not-so-fun under the car stuff starts tomorrow... also with hydraulic timing chain tension’ers... those will be a pain to work around...
SWB |
"i wasent sure where i was going to put the oil tank vent line...if thats what you call it..
i sure dont want the oil tank under boost so i attached to a un-used hole on the right side of the airbox.... before the sensor plate..." Search the archives under "oil tank venting". Same applies to a turbo. You'll want to install a catch can to help separate oil/gas from the air flow before recirculating back into the engine. Sherwood |
isnt that what that little metal "L" with the copper(?) spounge in it is for?
SWB |
well.... i put it all back to stock... just couldent get it to work..
pictures will come later tonight when i upload them... basicly.. i can get the turbo highenough to have it grav drain... its touching the motor mount crossmember..... i give up for now... i have to take the car to cali on the 17th so i cant have it in pieces... can i just plug up the oil return line that i taped? and can i just plug up the oil feed line? gerr... 3 days and i cant make it work... makes me want to get rid of it... that or buy the old style HE;s becacuse i had to make my own later style adapter and i cant get it high enough...
SWB |
as you can see i cant even slide my pinky inbetween that crossmember and the top of the compressor... but its still not high enough to drain... [img] You leave your buddy with the high temp gasket stuff and look what happens dont worry i took it back off and removed most of it..
SWB |
Nick, try contacting Sammy G, tsuter for suggestions and look over tsuters original thread for ideas, one thing I know is the mounting flange was mounted at an angle to perhaps give you more room up and out.
911SC Turbo
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
i had the mounting flange at an angle...
but its hiting the turbo smack dab in the middle... lowest spot on the compresser side.. and the exhaust side is just slightly lower.. i will re-lookover it.. im contimplating backdating HE;s just to end this guessing on where the turbo needs to be located... ive spent so much money already... save me!that or taking a lump of money to the local shop and taking all the pictures i can find of of the install and saying... "everyhting's done except this god dam exhaust pipe... make me one that works!" now that i look at it... maybe i will just take it to the shop all put together... and they can bend me a pipe thats closer...to the pictures...
SWB Last edited by air-cool-me; 03-13-2005 at 09:27 PM.. |
drag racing the short bus
At least you gave it the old college try. I'm sorry I came late to this thread and might have missed some basic information...
1) Is that an SC engine you're trying to install it on? If so, what year SC engine? 2) How much boost were you thinking of running? Thanks.
The Terror of Tiny Town |
6lbs
SWB |
Original Owner
It looks like the turbo needs to be reclocked. The Turbo outlet should be at 11:00 o'clock vs the oil supply and drain.
I can post a drawing... but not this week. This is without a doubt the finest picture I have seen on this forum!!! And deserves a bump!!!
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
I am trying to remember how that cross over pipe looked but it seems to me that the flange was angled two ways it was canted forward and sideways. I hope you still have all the ss pipe I sent you, there should be enough to redo the job. You can always use flexible aluminum hose to figure out the run and have it duplicated, I would install the intake and compressor pipes also so you will know exactly were the turbo needs to be.
Get that turbo angled right and you might be able to fit that Flowmaster muffler in. I always look at it this way, figure out were everything fits then find the easiest path to connect it all up. It took me three tries fabricating my crossover pipe in the 914. Keep us informed
Here is a shot of Kurts crossover pipe that he fabricated. I got from Tsutter's turbo sc thread.
the on the side system comes from a 2.5inch pipe... so cant use the 2inch.. the three inch elbow is used for my dump pipe right now.. untill i can fit the flowmaster.. so i guess im going with non ss stuff as of right now i put it back together and im going to drive it to the local "air cooled only" shop.. i will install all the boost pipes and then push the car into the shop for them to make the exhaust pipe... i was quoted 140$ and up to make the pipe i will be bringing all the pictures i can find to help.. might just go with the older style HE's... hes got a pair... i know its the cough out way to do it... but i cant seem to get that pipe in the right spot.. ![]() at least i learned alot jaming my head into the cis and laying on my back for two days!
SWB Last edited by air-cool-me; 03-14-2005 at 03:13 PM.. |
hahah that old thing! thats my buddies "capri"(sp)
its stiffer and lower and bult slightly... 1000miles on a rebuild... but it still handles like a mustang VERY fun in the wet...(closed track) has plunty of TQ and so little grip that it slides all over the place...
SWB |
If the turbo drain is in the right spot with the boost and intake pipes in position, then it's a small matter of fabricating a new exhaust inlet pipe or modifying the current one to fit. If the turbo drain elevation is not correct, you'll have to modify all the pipes. Make sure you support the turbo with another bracket.
After you fine tune the setup , you may want to make another exhaust inlet pipe out of stainless steel. The mild steel pipe will wear out quickly due to the heat and elements. My $.02, Sherwood |
I have some 2.5 SS pipe also, do you think you may need it.
let me get everything set in mild steel....i dont have SSI's so im sure the HE's would be gone by now if it was that big of a deal..
the intake pipes have alot of wiggle room, i just need to wiggle them closer to the drain.. that and angle the turbo more... then i think ive got it
SWB |
Keep going were watching, I will have pipe if you need it later.
I cant wait to hear your responce after the first test drive, remember to warm the engine up to operating temp before you step on it.
