A/C Delete Question
Hi all, I've sort of started the quest of lightness and pulled the A/C this weekend, and face it, it's a Targa who needs A/C?. Well I've got everything out except the mounting bracket for the compressor. It looks like it has a couple mounting points down below, near the muffler. Do I have to remove the muffler to get this off? I'd like to realize the benifits of the extra room on that side of the motor for my first ever valve adjustment in the next couple of weeks.
Thanks,
Kris
1986 Targa
1993 Corrado VR6
2005 325xi
2010 135i
2011 X5d
Old 03-14-2005, 03:49 PM
Monkey Wrench
Spede's Avatar
I don't think I was able to get my AC bracket off without removing my muffler.
Old 03-14-2005, 03:58 PM
another round please
strupgolf's Avatar
I did the exact same thing this weekend and cant figure out how to get the bracket off. Any help?
Getting old is not for wimps.
Old 03-14-2005, 04:08 PM
Monkey Wrench
Spede's Avatar
You guys will see the two bolts that attaches the backet as soon as you remove the muffler.
Old 03-14-2005, 04:19 PM
PORSCHEGOBOY's Avatar
ac removal
yep removed my bracket this past weekend drop muffler you will find 2bolts in the engine compartment 2 10mm nuts and a allen bolt under the bracket lots of room for vavle adj and plug replacement good luck
Old 03-14-2005, 04:51 PM
Anyone have an a/c bracket for a 2.7 that holds a rotary style compressor they would like to sell? Joel
Old 03-14-2005, 11:49 PM
ruf-porsche's Avatar
You need the old bracket plus an adapter bracket. PORSCHE never installed a rotary compressor in any of their cars. They used a wobble plate compressor for their later cars.
Old 03-15-2005, 04:03 AM
Thanks, that is what I ment to say. If i could get a delco d8 in there I would love it. I have serveral laying around and I know how to rebuild them.....
Old 03-15-2005, 11:10 PM
Sanden to York
Go to ebay and do a search on sanden and york. I brought a bracket on ebay from a store in texas that allow you to mount a Sanden compressor where a York compressor was previously used.
My old york is still working, so I haven't done the conversion, but I also brought a seiki seiko compressor with bracket on this forum.
Old 03-16-2005, 06:08 AM
Noel's Avatar
The other guys are correct about the compressor bracket on a Carrera. However, for SC guys reading this thread, this only applys to Carreras. The bracket on the SCs can be removed without removing the muffler.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 03-16-2005, 06:12 AM
tubwreck's Avatar
OK AC Delete guys: When you removed the compressor bracket from your 3.2, what did you do about the little rectangular hole that was left in the tin behind the engine?
(a) Nothing
(b) Pop-rivet a scrap of aluminum in there
(c) Special order non-AC rear tin from Germany at huge expense, then pull engine in order to replace it.
Thanks!
Old 05-12-2005, 05:07 PM
Noel's Avatar
I left the hole in mine, but on an SC it really isn't a very big hole.
Old 05-12-2005, 05:12 PM
tubwreck's Avatar
About 1" by 2" near the cam oil line.
Old 05-13-2005, 05:24 AM
I cut a piece of sheet metal to fill the hole on mine. I don't know if it's necessary (for proper air flow) or not, but I just didn't want the hole there.
Old 05-13-2005, 05:59 AM
I've asked this before but never got an answer. Will the later style aluminum compressor bracket mount on a 3 liter SC engine?
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 05-13-2005, 06:12 AM
Noel's Avatar
I don't think it will. I have all of the OEM bracket from my SC if you need them. PM me.
Old 05-13-2005, 06:23 AM
