drummer323's Avatar
T Bar Question for 3.6 conversion
Hi, I just got my new roller delivered last night. It's a '77 sunroof coupe. I'm doing a 935 body style conversion and will be going with a 3.6. What size T bars should I go with? The front end of the car is all fiberglass panels and hood. The rockers are fiberglass and I have a huge 935 tail in fiberglass and also the rear bumper and front air dams are fiberglass. I am doing suspension mods including the following: It has adjustable springplates, front and rear bilsteins, rear monoballs, front camber plates, 22mm frt/rr weltmeister sways, turbo tie rods, bronze bushings in front and rear poly-bronze bushings (Elephant Racing) I plan to use their T bars as well thru our host to purchase. I have C2 front calipers, cross drilled rotors and 225's on the front and 345's in the rear on 15" rims. My thoughts are a 22mm front bar and 29 or 30 rear bar. Am I thinking correct for the 3.6 weight difference? This is a street car and not used for long haul and my wife will take occasional rides but it is mostly my toy and I don't mind the stiffer settings but obviously the street vs. track surface is different and my settings are more track oriented than street. So advise me!
1977 911 with major upgrades!
Old 03-16-2005, 07:33 AM
rdane's Avatar
I run mono balls, 22 sways, and 22/30 Sanders bars on a 2200# high performance street car. Actually two of them..one with a 3.4 the other with a '95 3.6.
Old 03-16-2005, 08:02 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
Im running 23 and 31s. Car used primarily for the track.
Marc
Old 03-16-2005, 08:38 PM
With a 110 mm tire width difference ( ! ) front/rear....I'd go closer to 31 instead of 29 or 30.
3.6...by itself...is not that much more weight than 2.0, believe it or not...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-17-2005, 12:07 PM
