dandrews64's Avatar
My 3.0L 82 SC uses roughly a quart per 1,000 miles. 139K miles on the ODO. From this thread, that's actually OK (I thought it was bad). No drips on garage floor.
Recently properly checked oil level was at bottom line on dipstick - two quarts brought it up to top line.
Doug Andrews
1982 911SC Targa
2008 Silverado Duramax 3/4 ton
2004 Armada
1999 Honda XR400
Old 03-18-2005, 09:53 AM
MBruns for President
JeremyD's Avatar
And at the top line, warm weather you run the risk of having some of the oil make it's way into your breather - and smoking... You should really keep the oil level between the botom line - and 1/2 way between the hashes...
Old 03-18-2005, 09:56 AM
Senior Member
Superman's Avatar
John Walker does my work.
I would not do a top end job on a Carrera without also doing the bottom end. For the purpose of changing the wimpy rod bolts out.
You can check your valve guides, but not by looking at the dip stick. You'd have to remove valve covers, turn the engine so a valve is slightly depressed, and then try to rock the valve stem back and forth.
Mocha 1978 911SC. "Coco"
Old 03-18-2005, 10:06 AM
dandrews64's Avatar
Jeremy good advice, thanks.
I have overheating problems (described on the 'two worst mods' thread) and started thinking that running too little oil might be the cause.
BTW, your car is quite beautiful.
Doug Andrews
1982 911SC Targa
2004 Armada
1999 Honda XR400
Old 03-18-2005, 02:03 PM
RideShoot&Drink's Avatar
Send a message via Yahoo to RideShoot&Drink
I'd give this guy a call 408.429.0545. His name is Tom Amon. He is mobile mechanic with great experience. He has been working on my car lately, and I'm very happy!
I'm in heaven, when I drive my nine eleven...
Old 03-18-2005, 02:15 PM
cantdrv55's Avatar
Thanks for his number. His compadre has already PM'd me. They lurk here. Pretty smart actually.
Old 03-18-2005, 02:48 PM
Yeah, there are several threads on this board about Tom, here is one of them:
Tom Amon Mobile Works West: veteran mechanic at your doorstep
Old 03-18-2005, 03:28 PM
