abit off center
Headers and Oxygen Sensors?
Im running B&B headers on my 86 3.2 they put the oxygen sensor on the left bank of cylinders, it is not reading the complete exhaust like the stock setup, is this ok? or should it not be used on this type of header setup?
Thanks Craig |
In gerneral it doesn't cause any problems. Now if there is an issue on the passenger side only it won't be registered or corrected by the cpu.
Check if the O2 sensor are in the same stock distance in factory headers in the B&B headers. If you put the O2 too far, it will read wrong because the will feel less heat.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
abit off center
Its further down stream because the stock setup places it in front of the cat, The B&B has the sensor in the collector just before the muffler, I checked the voltage of the sensor when hot and running, its right around .72 to .76 volts, seems to be within range but on the richer side.
Craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
