Anyone had this rust problem?
It would appear that the blower drain has become blocked and caused this
Classic 1969 911T |
I would track hard to find leaks with white caulk mixed with water.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Was this a LHD car converted to RHD?
Blower drain or after market a/c drain? |
Yeah it's an origional RHD car imported into Australia in 1969. To me it would appear that the tube is the drain from the blower.
I've had a good stab around and it would appear that it's mainly surface rust. I'll know more when i get the pedel cluster and the rest of the carpet out today.
Classic 1969 911T Last edited by Classic; 03-22-2005 at 10:36 AM.. |
Hmmm, my 78 has a plastic drain hose that runs thru the smugglers box..now that I see the car is a 69 to correct my answer to your other thread question about that green patch that is covering the hole in the bulkhead..might be for the gas heater wiring.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Looks like a job for POR 15
regards, jlex.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Bird. It's the word...
Classic,
My Aussie delivery RHD also suffered surface rust like this when I got it, but mine was caused by a leaking windscreen seal. Basically I just got in to it with a wire wheel and hit it with Wattyl and Killrust products... no problem for the past 3 years. Though given that POR15 is available over here, that might be a proven choice. Don't panic ![]() Also, rebuild your cluster whilst it is out - if it hasn't been done before, it will be due soon!
John Forcier Current: 68L 2.0 Hotrod - build underway |
thanks guys yeah i got the cluster out today and it's only surface rust other then the tube. I think i'll cut it off and weld in a new section,once i work out how to get the mig at the back.
Classic 1969 911T |
I have a similar leak in my 1976 Aust compliance also. I have tried to chase it ia a weak manner. But I suspect it is not the windscreen as I have covered the air inlet below the windscreen and stopped the leak.
I have heard that the air inlet has a drain. Does anyone have a photo of where the drain for the air inlet is? regards Andrew
Andrew Johnson Newcastle , Australia 1976, 911 ROW no mods previous car Mercedes 280CE 1979. Other car 2004 Peugeot 307 Wife's & Family Truckster |
'77 US with AC
