Classic's Avatar
Anyone had this rust problem?
It would appear that the blower drain has become blocked and caused this
Classic 1969 911T
Old 03-22-2005, 02:14 AM
I would track hard to find leaks with white caulk mixed with water.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-22-2005, 04:42 AM
ruf-porsche's Avatar
Was this a LHD car converted to RHD?
Blower drain or after market a/c drain?
Old 03-22-2005, 07:07 AM
Classic's Avatar
Yeah it's an origional RHD car imported into Australia in 1969. To me it would appear that the tube is the drain from the blower.
I've had a good stab around and it would appear that it's mainly surface rust.
I'll know more when i get the pedel cluster and the rest of the carpet out today.
Classic 1969 911T
Old 03-22-2005, 10:33 AM
Hmmm, my 78 has a plastic drain hose that runs thru the smugglers box..now that I see the car is a 69 to correct my answer to your other thread question about that green patch that is covering the hole in the bulkhead..might be for the gas heater wiring.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 03-22-2005, 10:48 AM
Looks like a job for POR 15
regards,
jlex.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-22-2005, 01:21 PM
Bird. It's the word...
Fishcop's Avatar
Classic,
My Aussie delivery RHD also suffered surface rust like this when I got it, but mine was caused by a leaking windscreen seal.
Basically I just got in to it with a wire wheel and hit it with Wattyl and Killrust products... no problem for the past 3 years. Though given that POR15 is available over here, that might be a proven choice. Don't panic
Also, rebuild your cluster whilst it is out - if it hasn't been done before, it will be due soon!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-22-2005, 03:56 PM
Classic's Avatar
thanks guys yeah i got the cluster out today and it's only surface rust other then the tube. I think i'll cut it off and weld in a new section,once i work out how to get the mig at the back.
Classic 1969 911T
Old 03-23-2005, 02:26 AM
andrew johnson's Avatar
I have a similar leak in my 1976 Aust compliance also. I have tried to chase it ia a weak manner. But I suspect it is not the windscreen as I have covered the air inlet below the windscreen and stopped the leak.
I have heard that the air inlet has a drain.
Does anyone have a photo of where the drain for the air inlet is?
regards
Andrew
Andrew Johnson
Newcastle , Australia
1976, 911 ROW
no mods
previous car
Mercedes 280CE 1979.
Other car
2004 Peugeot 307
Wife's & Family Truckster
Old 03-23-2005, 03:12 AM
'77 US with AC
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-23-2005, 05:01 AM
