Administrator
Just to be clear, my expectations on the diffuser are nil.
I fabricated the more-aggressive splitter and side skirts, and I expect that by limiting air passage under the car, I'll see a benefit. There are loads of race cars out there doing the same, so this isn't that big a leap. My home-made skirts are probably less effective than commercially-available pieces, but mine are cheap and easy to remove for the drive home. The flat plastic panel under my car was also an easy decision. My testing was by no means scientific, but it was less than $30, and produced an immediate reduction in my lap times. Remember that my car has an underbelly AC condenser, which (apparently) had a detrimental effect on the 911's under-car aerodynamics. The diffuser was an afterthought. I already had the tools out. My thinking is that if I'm able to come up with a fairly reliable way of measuring the effect of these pieces (as well as different wing settings and different tails) -- whether it be a couple of bicycle wheels or a set of strain gauges, wool tufts, or a combination of all three -- then I'll test everything I've got, including the diffuser. But it's the one piece of the whole group that was done just for kicks.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
It doesn't have to be as flat as a pancake (or as Kansas, which is now known to be flatter than a pnacake).... but the flow has to be pretty "flat" w/o many large eddies.
Now -- Jack how far are you willing to have stuff stick out behind the car? That will help with the issues above. You could even rename it "Langenblack." Or if you don't like that one, "Black Booty II."
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Administrator
Some final pictures, before I take it back off:
Smooth, from head to tail: The next step is to find a way to monitor cylinder head temps, so that I can be sure the experiment doesn't do more harm than good.
Think about bashing the leading edge of those holes upwards -- for more air flow. Maybe NACA ducts would be good to use on the undertray also (or you can use the more advanced NASA ducts).
I think the Keebler elves could use that to slice cookie dough or something...
Jack, when do you sleep? or do you not work?
'83 SC |
Jack - Seirously, how did you make it?
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Administrator
I assume the factory did it this way in order to prevent a high-pressure pocket from forming? Do you think it might work? (Or am I more like a monkey who's found some old circuit boards and a suitcase, and thinks he can turn it all into a laptop computer?)
PRO Motorsports
Jack, the slots on the sides of my 964 undertray are very important. They are there to let the air escape from the cylinder heads. The big middle openings are only for the cylinders.
You can see that I had drilled more holes in the undertray to aid in cooling before I simply took it off altogether.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
That's neat looking - now you need a CF version...
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Administrator
It's a cool idea, but I don't think the curve is gradual enough so I suspect the air is separating before it gets a chance to accelerate.
1987 Ferrari diffuser:
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) Last edited by David; 03-30-2005 at 12:45 PM.. |
MBruns for President
Cool idea. I would recommend cutting up a kite (nylon, lightweight ripstop) and taping that to your car. Then I would get someone to follow me with a video camera in their car and record my car and the streamers on it. That will give you a good idea on laminar flow before you get to the track. There is an optimal curve for air (just like water) you might do a search on line, believe it a NACA prfile and you may be able to download profiles/templates before going further.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
It makes sense now that i see the other side...
re monkey issues... Well, that is pretty much the way fluid dynamics works. Nothing is better than an educated guess b/c the fundamental equations have never been solved. All the models you see are simply numeric approximations... Just be careful with the head temps. - I know you will be... And if not, your car will be even faster when the new 3.8L RS engine goes in...
put CHT's on the two heads that are not uncoverd... run it...(or all... to be safe)
i bet those will get the the most toasty... you can always pit and remove the thing before the CHT's go way up... or... bring a drill and add some hole's then you can collect usefull data on just the sideskirts and the front... but i think i am suffering from "not my car syndrome" or NMCS or maybe "MWSFT" (my wallet safe from this) or maybe even "TSIBIDHTPTRBSIWTHTJDI" (this sounds iffy but i dont have to pay the repair bill, so i will tell him to just do it)
SWB |
Keith 1979 930 2007 WRX wagon |
Jack the diffuser looks great when do you going to test it?
about GT rules: maserati have one gt race car: st. car: enzo: ferrari CS: F50 LM
X/A |
Administrator
Yellowbird,
After looking more, I think I'm half wrong. I remember hearing that the Maserati was a racing version of the Enzo and that they had to remove the diffuser, this is plainly wrong as you have pictures of them with diffusers. However, after looking at ALMS rules and finding some pictures it appears that the higher GTS class allows diffusers, but the GT class, which Bill's GT3RSR pictures were from does NOT allow diffusers. Check out the GT class 360 below. It doesn't have a diffuser. However, I'm sure if they allowed it, this car would have one and maybe the RSRs too. So in summation: it seems GTS allows it, GT does not (from what I've gathered). Now GTS is called GT1 and GT is called GT2 (I think), I'm not sure if this policy with diffusers has continued.
I think you need a spot where you can exit hot engine/exhaust air (and the air you're scooping up from the openings under the engine)
If you look at the pics of the other cars, you can see they all have that (above the difuser) How about putting some louvres (openings facing to the back) in the sloping part of your difuser?
WWW.9GEAR.NL |
