KNS KNS is offline
Sway Bar Bushing Question
I'm going to be changing out the swaybar bushings (along with a bunch of other suspension work) for new, stock rubber bushings. The Bentley manual says to use Contiflix lubricant on the new bushings. I'm sure this isn't a must-have. Any other similar (silacone-type) products out there that are just as good?
Thanks..
Kurt
Old 06-11-2005, 07:29 AM
jtkkz's Avatar
I use to owna bike shop, and remembered that grip shift company made a thick, sticky lube called (grip shift snot lube) you can probably get them at your local bike shop who carries them.
They actually work very well, I have used in all my past 911's sway bar bushings.
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 06-11-2005, 07:38 AM
KNS KNS is offline
Thank you.
Anybody else using other products?
Kurt
Old 06-11-2005, 08:49 AM
Nine9six's Avatar
I was thinking of snorting some to relieve this nasty congestion...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 06-11-2005, 09:15 AM
Early_S_Man's Avatar
Porsche Crest
Kurt,
As usual ... any of the Dow Corning 4, 111, or 112 silicone greases work well! TRW Sil-Glyd would work, too, but not my recommendation!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-11-2005, 09:38 AM
