Sway Bar Bushing Question
I'm going to be changing out the swaybar bushings (along with a bunch of other suspension work) for new, stock rubber bushings. The Bentley manual says to use Contiflix lubricant on the new bushings. I'm sure this isn't a must-have. Any other similar (silacone-type) products out there that are just as good?
Thanks..
Kurt |
I use to owna bike shop, and remembered that grip shift company made a thick, sticky lube called (grip shift snot lube) you can probably get them at your local bike shop who carries them.
They actually work very well, I have used in all my past 911's sway bar bushings. |
Thank you.
Anybody else using other products?
Kurt |
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Kurt,
As usual ... any of the Dow Corning 4, 111, or 112 silicone greases work well! TRW Sil-Glyd would work, too, but not my recommendation!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thread Tools | |
Rate This Thread | |
