Which 3.6 chip to use???
When I was getting my 3.6 conversion together I used a cyntex chip and it works fine. During the engine buying process the seller of the motor sold me a chip that he said a Euro RS chip which was tuned to work with a 3.6 that has light weight flywheel. I never used it because I did'nt know who made it; I didn't want to blow the motor in the event it was not programmed properly. Is there anyway to read the chips fuel and timing maps to make sure it is safe to use or should I just leave it alone?
Old 03-25-2005, 10:49 PM
Nine9six's Avatar
Why not contact Steve Wong at http://www.911chips.com/
Steve is extremely knowledgable, and always willing to help.
Best regards,
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-26-2005, 09:27 AM
I'll send him an email - thanks.
Old 03-26-2005, 03:52 PM
Administrator
Jack Olsen's Avatar
I use the No Bad Days chip, which is a switched, two-position chip for the 3.6. On days you don't need it (with California gas in the heat, for example), you run it in the stock setting, and get the safer fuel mapping ratios. When you need the extra umph, you switch it to the modified setting, and get your power on demand.
Old 03-26-2005, 04:09 PM
RETIRED
Joe Bob's Avatar
Yupz.....No Bad Days ....I run it as well....not a hiccup. Contact Ingo Schmidt on this board...he also has a chip reader.
2012 ML350 3.0 Turbo Diesel
Old 03-26-2005, 04:49 PM
Is there a NBD chip for the 993? I'll send Indo an email.
Old 03-26-2005, 07:33 PM
RETIRED
Joe Bob's Avatar
http://forums.pelicanparts.com/members/9318.html?action=getinfo
He posts under this....
Old 03-26-2005, 08:18 PM
Thanks Mike - I just sent him an email.
Old 03-26-2005, 11:04 PM
