930 Temp Sensor
Does anyone know what the sensor (I think it's a temperature sensor) on the left rear of a 1977 930 is used for? It's situated in the left rear chain case cover and has 2 wires running to it.
Cheers
PaulM 1977 930 1993 Nissan GT-IR 2000 Subaru WRX |
If it's a big "bell-type" sensor it's oil-pressure sender...if it's only a small threaded senbsor it's oil-temperature sender.
My PET says it's a temperature-sender....part nr. 911 617 117 00
Thank you for your time, |
I think that one is for the CIS. I think it is called the themo time sw.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Thanks guys. I'am just going through and removing stuff from the engine wiring loom that I don't need anymore since the engine was converted to EFI. Looks like the wires for this one can go too.
Cheers
