Shaun @ Tru6's Avatar
69E Torsion bar size and other questions
I'm planning a suspension upgrade on my E in the future including turbo tierods and Koni struts in the front with all new hardware, adjustable spring plates in the rear. Whole car will be lowered.
Questions
this is already a light car, what would be a better match, 21/27 bars or 22/27 bars. Car is getting 205/55/15s on deep 6s in the front, 225/50s on the rear.
Bilstein sports on the rear are only available for 72-73 cars. Is there any way to make these work for my 69?
Perhaps the most important question: should I stick with 19/24 bars left over from my 84 and invest the torsion money into sway bars, of which the car has none. If so, recommendations?
Tru6 Restoration & Design
Old 04-04-2005, 05:44 AM
Shawn -
I've got some bigger torsion bars left over from a previous racecar. Not sure of the sizes off the top of my head - come on over a take a look. Normal frequent flyer discount applies. Jim 781-801-3678
Old 04-04-2005, 06:04 AM
IROC's Avatar
IMHO, unless this is going to be a track car or your roads are really smooth, the 22s in the front are a little stiff. I have 22s in the front of my 2400lb '76 and they can be tiresome on rough roads.
I'd say 21/27s...
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-04-2005, 07:41 AM
RallyJon's Avatar
The 72- shocks are a lot longer. You'd need to swap in later banana arms to use the later shocks or you'll have no jounce travel.
993 · 911 · STI · S4 · rally car
Old 04-04-2005, 07:46 AM
Chuck Moreland's Avatar
Sounds like a steet only car? I'd go 21/27 if you want more control than the carrera bars offer. And I'd go with HDs, not sports.
Chuck Moreland - elephantracing.com - vonnen.com
Old 04-04-2005, 08:50 AM
I'm currently going through mine also, 73T. After reading previous post I am going with Bilstein HD all around with 21/26 torsions. I am also adding sway bars. I picked up some used sways for not alot of money. Im still waiting on the brackets to weld up on the rear. I currently have everything apart and replacing all the bushings while I'm at it. I figured I might as well go with the sway bars too.
The car handled very poorly when I picked it up so I don't know what effect each part will have but every bushing and shock was shot.
Ive got to get mine back together as its taken me longer than I expected. I'm waiting to get the A-arms powdercoated. I figure while everythings apart I may as well make it look nice too.
Good luck. You know you'll get hit with the "while your in there". I always do.
2000 Boxster S (gone)
1972 911s Targa (sold)
1971 911t coupe roller (sold)
1973 911t coupe / 3.2 (sold)
Gruppe B #057
Old 04-04-2005, 09:14 AM
Thanks everyone for your good thoughts. Looks like I will be going with:
digging around Jim Logan's treasure trove to see what we come up with, if nothing, then
21/27s (will have to find used)
Koni struts up front
new ball joints/castle nuts/strut pins
turbo tie rods
Bilstein HD in the rear
Adjustable spring plates
lowered all around
Any thoughts on a front sway bar?
Old 04-05-2005, 03:41 AM
