Question How to fill transmission fluid?
An embarassing question - how do you fill fluids to the transmission (a 930 box)?
Mine is sitting on a bench & it looks to me like the fill hole is the 30mm plug on the driver side (tranny facing as if its in the car) just behind the throttle linkages?
I believe I need to level the transmission then fill till the fluid lines up at the bottom of the hole?
Does this sounds right? Really dont want to unscrew the wrong plug
Thanks..
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 04-05-2005, 08:38 AM
MuffinMan's Avatar
I typically use a hand pump to move the fluid into the hole. The proper level of fluid is as you describe... at the bottom of the hole, when on a flat surface.
Also, it sounds like you have the right plug.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 04-05-2005, 08:45 AM
Metal Guru
911nut's Avatar
If you don't have a hand pump use an oil funnel with some plastic tubing connected to it. Shove the tube into the fill hole and let gravity be your friend.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 04-05-2005, 08:48 AM
Thanks Rob...
I'm actually filling her with Mobil 1 as a trial & it looks like there's a nozzle tip so should be able to squeeze the fluid in straight from the bottle
Old 04-05-2005, 08:49 AM
Forgive the ignorance, but do you have the G-50 trans?
If you are the 915, it seems that the Swepco is the favorite from the other members on this board. Mobil is one of the favorites for the G-50
Just checking
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 04-05-2005, 08:59 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
I have a tried and true means of filling in under 15 minutes. First you need a funnel from Walmart that has a hose on it with a means to start and stop the flow (blue one with measurements on side is $3 or $4), then buy some extra hose of same size at Home Depot ($3 or $4 again), Swepco or tranny oil of choice. Heat largest pot of water you have until it boils, poor in to bucket large enough for swepco or oil container to fit in. Heated oil, funnel elevated to facilitate gravity, 3+ quarts later, 10 or so minutes. Your full. The trick is heat and elevation.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 04-05-2005, 09:08 AM
Jerome Ryals's Avatar
DonMo just described the way I do mine.
Old 04-05-2005, 09:26 AM
Chris, I have the 930 box. Hence the mentioning of trial. My mechanics prep a lot of race cars & he swears by Mobil 1 even on 915. So I thought I'll give it a try & see.
DonMo - thanks for the tips. I certainly will need it in future. This time, the tranny is sitting on the bench so pouring fluid in "should" be easy.
Old 04-05-2005, 10:02 AM
