Stubborn Drain Plug - Help!
Okay, I was in the process of changing the oil. Drained the oil from the sump and moved on to the oil tank. The plug won't budge. I don't know whether it's overtorqued or if it's rusted.
Problem is, I don't have impact tools here in garage. I'll have to get it to the shop. When I try to budge it with the ratchet, all it does is wiggle the tank. I don't want to bust anything. I've sprayed it with liquid wrench for a week now. I've tried tapping the end of the ratchet with a rubber hammer. Looks like I'll have to put oil back in her to get her to the shop. Question is, how much? I have no idea how much is in there after draining the sump. I guess I could try to pour the drained oil into measurable containers. Suggestions on the plug or the oil? Jim
Jim Dean LL.B. - London, Ont, Canada. 1969 911T "Blood Orange" Euro (Brought over from Germany in 86) Engine and brake system rebuilds 2006 & 2007 "Oversteer scares passengers, understeer scares drivers." |
Re: Stubborn Drain Plug - Help!
Also, have you tried tightening the plug just a bit? Sometimes that will break loose the corrosion and then let you back it out. Good luck!
1984 Targa |
Good thought Scott. I'll try to snug it a tad and then see if it releases. Again though, I'm not sure if it's overtorqued or rusted. Haven't seen any PB blaster up here.
I'll be near a Miejers in Michigan in a week, do you know if they carry it there? Jim
Hey Buddy, use a 6 point wrench or socket and pull on that facker ,prolly won't break anything cept mabe your nuckles !
Luck !! Manfred
1986 911 Carrera Coupe - Hers 1973 911 T - in progress - His |
Have you tried heat? I would never have believed it, but I've used an el-cheapo heat gun to do amazing things. Also, when using PB Blaster (or similar), try applying it, then waiting a moment, then tapping with something metal (like a ball peen hammer, of the sort that you'd use to make aerodynamic golf-ball dimples on the underside of your car).
Dan
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
Don't know if you can get it there...but you can go to www.pbblaster.com and check. (BTW, the website is down as I write this.) Most of the major auto parts houses carry it, I think.
I also thought heat might help, but can you get it hot enough without risking something that would require Red Adair's people to snuff!
1984 Targa |
My local Meijer carries it.
95 540i/6 89 R100RS |
Kinda hard to believe you need a rust-off penetrant to get an *oil* drain plug out...I mean..it won't be dry and rusted now....would it ??
Different problem maybe ? ......... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 04-05-2005 at 06:58 AM.. |
Agree w/Wil-I suspect someone used gorilla force. Rather than moving the car, I'd try to get an air tank, like people take to an a/x to fill tires. Fill it to the max safe pressure, and use an impact. If that fails, then I'd think shop.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Breaker bar and pipe. Get to a good pressure and give a couple of all out yanks.
Warren & Ron, may you rest in Peace. |
When my case plug wouldn't come out, I used a good pair of locking pliers with nice, sharp teeth. I mangled the plug, but they're disposable anyway. Just took a lot of pressure, and cursing. more so since the car wasn't on a lift. Just crank on the thing, like these guys are saying.
You remembered left-loose, right-tight, correct? Just checking.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
PBBlaster and pipe for leverage on the wrench.
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
![]() Dan
Just don't confuse "bird's eye view" ...with "worm's eye view".....
All will come right...... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
