copper's Avatar
Stubborn Drain Plug - Help!
Okay, I was in the process of changing the oil. Drained the oil from the sump and moved on to the oil tank. The plug won't budge. I don't know whether it's overtorqued or if it's rusted.
Problem is, I don't have impact tools here in garage. I'll have to get it to the shop. When I try to budge it with the ratchet, all it does is wiggle the tank.
I don't want to bust anything. I've sprayed it with liquid wrench for a week now. I've tried tapping the end of the ratchet with a rubber hammer.
Looks like I'll have to put oil back in her to get her to the shop.
Question is, how much?
I have no idea how much is in there after draining the sump. I guess I could try to pour the drained oil into measurable containers.
Suggestions on the plug or the oil?
Jim
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 04-04-2005, 02:10 PM
scottb's Avatar
Re: Stubborn Drain Plug - Help!
Have you tried PB Blaster? The stuff is magic. If you can find some up there north of the border, try spraying it on liberally for a few days and then give it a go.
Also, have you tried tightening the plug just a bit? Sometimes that will break loose the corrosion and then let you back it out.
Good luck!
1984 Targa
Old 04-04-2005, 03:07 PM
copper's Avatar
Good thought Scott. I'll try to snug it a tad and then see if it releases. Again though, I'm not sure if it's overtorqued or rusted. Haven't seen any PB blaster up here.
I'll be near a Miejers in Michigan in a week, do you know if they carry it there?
Jim
Old 04-04-2005, 03:20 PM
Kryptonite's Avatar
Hey Buddy, use a 6 point wrench or socket and pull on that facker ,prolly won't break anything cept mabe your nuckles !
Luck !!
Manfred
1986 911 Carrera Coupe - Hers
1973 911 T - in progress - His
Old 04-04-2005, 03:23 PM
djmcmath's Avatar
Have you tried heat? I would never have believed it, but I've used an el-cheapo heat gun to do amazing things. Also, when using PB Blaster (or similar), try applying it, then waiting a moment, then tapping with something metal (like a ball peen hammer, of the sort that you'd use to make aerodynamic golf-ball dimples on the underside of your car).
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
scottb's Avatar
Don't know if you can get it there...but you can go to www.pbblaster.com and check. (BTW, the website is down as I write this.) Most of the major auto parts houses carry it, I think.
I also thought heat might help, but can you get it hot enough without risking something that would require Red Adair's people to snuff!
1984 Targa
Old 04-04-2005, 03:25 PM
DeutschMark's Avatar
My local Meijer carries it.
95 540i/6
89 R100RS
Old 04-04-2005, 03:27 PM
Kinda hard to believe you need a rust-off penetrant to get an *oil* drain plug out...I mean..it won't be dry and rusted now....would it ??
Different problem maybe ? .........
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-05-2005, 04:55 AM
greglepore's Avatar
Agree w/Wil-I suspect someone used gorilla force. Rather than moving the car, I'd try to get an air tank, like people take to an a/x to fill tires. Fill it to the max safe pressure, and use an impact. If that fails, then I'd think shop.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 04-05-2005, 06:28 AM
Breaker bar and pipe. Get to a good pressure and give a couple of all out yanks.
Warren & Ron, may you rest in Peace.
Old 04-05-2005, 07:02 AM
When my case plug wouldn't come out, I used a good pair of locking pliers with nice, sharp teeth. I mangled the plug, but they're disposable anyway. Just took a lot of pressure, and cursing. more so since the car wasn't on a lift. Just crank on the thing, like these guys are saying.
You remembered left-loose, right-tight, correct? Just checking.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 04-05-2005, 07:28 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
PBBlaster and pipe for leverage on the wrench.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 04-05-2005, 08:10 AM
djmcmath's Avatar
To keep myself from getting confused on that when I'm working upside-down and backwards, I use a ratchet the first time. Before I stick the ratchet into the space, I make sure that I have it in the "go looser" direction. Then I know when I put a Real Big Tool on it that I'm pulling the right way.
Dan
Old 04-05-2005, 09:19 AM
Just don't confuse "bird's eye view" ...with "worm's eye view".....
All will come right......
Wil
Wil Ferch
Old 04-05-2005, 09:22 AM
