Me like track days
Craig 930 RS's Avatar
Arrow *ALIGNMENT - post Elephant install - specs
Alignment after Elephant install -
Got your reading glasses on? Ridiculously hard to read:
2.2 neg camber front, 2.8 rear.
This was the max they could get side-to-side
Blend this post with these others:
* CORNER balanced - numbers from this...and the weight
* ELEPHANT rear suspension install *
* Elephant polybronze bushing INSTALL -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 04-05-2005, 12:00 PM
don911's Avatar
Are you using the elephant upper monoballs? 2.2 is really good. I was able to get -2.0 using the wevo camber king mono ball set up.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 04-05-2005, 12:03 PM
Me like track days
I bought the Smart Racing m-ball setup --- RIGHT before Hayden came out with his setup.
I wish I had more than 2.2 up front - especialy since the JRZ struts supposedly ahve 1+ degree negative camber built in.
Don - How well does 2.0 work with the Proxes RA/1s?
Old 04-05-2005, 12:15 PM
MuffinMan's Avatar
You can always add the Elephant Racing offset ball joints. I have them, and they supposedly yield up to 3/4 degree of additional negative camber.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 04-05-2005, 12:19 PM
Chuck Moreland's Avatar
2.2 is much more than a factory setup would allow, so yes your spindles are de-cambered.
Chuck Moreland - elephantracing.com - vonnen.com
Old 04-05-2005, 12:29 PM
Administrator
Jack Olsen's Avatar
2.2 is more than I run in front, and I sometimes think I'm running too much negative.
Old 04-05-2005, 12:41 PM
Friends of Warren
911teo's Avatar
How far would u go for a street/track car? I was thinking -1.6 -1.8on the front was already a lot.... -2.2 must wear your tires up very very quickly...
Matteo
Warren RIP
www.impactbumpers.co.uk
Old 04-05-2005, 12:49 PM
Me like track days
I've been running about 2.0-2.2 for a year now.
For some street use and lots of track use with A032R tires, it has yielded perfectly even wear across the tread.
YMMV, depending on use and tires -
Old 04-05-2005, 01:41 PM
Hey Craig....your (reminder) post quoting A032's reminds me of the long-lost discussions we had with the "Toddler" on Rennlist....
Ahh....the old days !!! ..... LOL !
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-05-2005, 02:20 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Depends on how wide your tires are also. I just aligned my today, with just monoballs and stock mountings, and the most i could get was -1.6 in the front.
Marc
Old 04-06-2005, 05:51 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
what exactly is the "preferred" alignment settings for a street/track combo car?
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 04-07-2005, 12:45 AM
randywebb's Avatar
There won't be an 'exact' one -- just take your pick on the Axis of Compromise.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-07-2005, 12:07 PM
Plavan's Avatar
I have 3 degree's (raised bilsteins with camber added) in the front and 2.5 in the rear. I love it. Strictly for a race car though
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 04-07-2005, 12:37 PM
Jack, I don't think that's true. You're running -2.25 up front, IIRC.
Old 04-07-2005, 12:48 PM
