front hub collar thingy
I removed my front disks last night and when I loosened the allen bolt in the collar for the front hub I could back it out by hand.
Question: When I reinstall it do I just hand tighten it untill there is no play in the front hub and lock it down? Or should I use channel locks to snug it up then back it off a few times to seat the hub? Gotta love those dust covers! I guess Germans hate dust.
Silver 1980SC Euro coupe |
I found out the hard way that you don't want it too tight; the bearings expand slightly when they get hot. I ruined a set of bearings in a single track day; ruined is putting it mildly; I had 1/4" of play in the road wheel by the time all was said and done!
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Tighten it down to seat the bearing and back it off slightly; just enough to where the slot washer can be moved using a screw driver.
The Fox Carrera |
Thanks!
