MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
So how did Porsche bump up the3.2 HP from 1986 to 1987? Didn't they remap the chip?
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
Irrationally exuberant
For example; Suppose prior to 1987 any motor that made less than 207hp on the dyno went back to be reworked. If they discovered that all the motors were making 210 hp anyway, they could, if they wanted to, raise the stated horsepower by 3hp to 210. Now suppose that happened AND they changed the chip mapping to give it another 7hp we'd get 217hp. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Bruce Anderson once said all 3.2s were essentially the same HP and performance...regardless of HP claims.
Certainly the 84-85 ( 86?) cars were mapped for USA 87 octane fuel...whereas the later cars required higher octane ( 91?) and theoretically made more hp. Smart tuners today use the same principles in getting a smidge more hp or drivability....and it won't blow up our cars if done carefully and with discretion.... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Sure are lots of "modified" 911 3.2 Carrera's out there running god knows what chips from the late 80's and 90's with 100k-200k miles on them and they finally blow and get a rebuild...
So the engine blows up and I get a rebuild or a 3.6 - What am I missing? Uhhh so. Who cares. 10k? Big deal. Most people chipping their late model Carrera's have some disposable income and are looking for a reason to mod. Let's dig up all the thread from this board that relate to engine failures due to chipping them...How many you got? It's kinda like one day we all know we are going to die but between then and now I just want to pack in some living...I think a chip does just that. Next topic? (Yawn.......)
Jeff |
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
There's a bit of misinformation in this information...
Sure 45 or 50 degrees of timing sounds like a lot, but that only applies at WOT. During part throttle conditions, engines can handle much more timing than "what Porsche techs consider the maximum advance". So comparing max WOT is really more important. A decent rule of thumb is 1 degree per octane point, but as with most things, you will reach a point of diminishing returns...
Matt B '73 911E |
Banned
Just guessing, Porsche began using Motronics 1.0 slightly earlier, probably because their small size allowed them to change to it quicker than others, and they may have employed 1.3 earlier as well. Last edited by fastpat; 04-11-2005 at 01:33 PM.. |
More Likeable IRL
where's the fun in this discussion? when does the poop start being flug about?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Author of "101 Projects"
Similar to what I wrote here:
http://www.pelicanparts.com/bmw/techarticles/Mult_Chip_Install/Mult_Chip_Install.htm As I state in 101 Projects, the installation of a chip is a good way to gain a few extra HP. Compared to major engine mods, it's a good bang for your buck. However, too agressive a mapping may indeed produce harmful detonation in your engine, which will slowly hammer it apart from the inside out. I believe that there are some nominal gains to be made from a more agressive mapping of the chip, but not too much. Porsche designed the chips for all types of conditions. The fact that the 1984-89 Motronic system doesn't have a knock sensor means that there's room left on the table for some power gains - at the risk of causing detonation. Later versions of the Motronic system will run as advanced as possible (in general) until the sensor detects knocking. You could conceivably run a larger advance if you're going to be running 94 octane or higher all the time (or if you run twin plugs). -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Banned
I really don't know if Jim Conforti developed Porsche Motronic chips for marketing by others
, but if he did, they'd likely be among the best. I don't dump chips, while I know what you mean, why waste your or my time? |
Loren is more than welcome here on the BBS. My rule of thumb is if you cause a lot of problems and trouble for me, you're going "to take a break." Loren apparently didn't appreciate this imposed "vacation" and thus became a bit sore at me. I suspect that in time, he will return in full force. -Wayne
Doesn't want/need a 3.6L
Having met Loren this weekend at the POC Tribute, I can say with 99.9% certainty that he is sitting back and laughing his !@# off at some of these posts.
He is a good guy, he's just having fun with some of you who take things a little too seriously. Hell, he got me in a pretty good lather a few months back as well when building my motor. It's just his way of having fun I guess. Why he wastes his time just stirring up trouble I don't know (or care for that matter), but some of you guys just routinely take the bait, over and over again. I really can't figure out though how he rationalizes that this can be good for his business. Ralph |
RETIRED
So Loren got a time out?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
