rotorhead's Avatar
How to start a 3.3 without the Air Filter?
Is it possible to start and run a 3.3turbo without the air filter or intercooler installed?
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 04-08-2005, 08:19 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Without the air filter- yes, without the intercooler- no.
Unless you run a tube from the turbo to the intake.
Marc
Old 04-08-2005, 08:22 PM
Crotchety Old Bastard
RarlyL8's Avatar
I did that this morning while playing with my fuel mixture.
You have to remove the intercooler in order to remove the stock air cleaner. Once that is done you either have to re-install the intercooler or run a pipe from the turbo to the throttle body.
Had I seen this post one hour ago I could have put a picture on for you.
Old 04-09-2005, 02:01 PM
Irrationally exuberant
ChrisBennet's Avatar
I know I ran a friends Turbo without the intercooler somehow last summer. If I remember, without the intercooler I heard a loud whistling while the car was turning over. I discovered the noise was coming from a small diameter vacuum type line. When I plugged the line, the motor would run. Hope that helps.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-09-2005, 02:17 PM
RarlyL8's Avatar
It is capable of running if that's what you're after. I personally don't like having exposed openings that my tools can fall into while the engine is on.
Old 04-09-2005, 02:24 PM
rotorhead's Avatar
Thanks guys
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 04-09-2005, 04:15 PM
