RallyJon's Avatar
Question Front end shake--what causes?
OTHER than wheel balance.
I had a bad vibration through the steering wheel. I noticed that the tabs on the balljoint lockplate had scraped off the wheel weights. So I took the front wheels and had them road-force balanced by a good local shop.
Problem is, there's still a pronounced shake from the front end at >60mph. Any idea what could cause this besides wheel balance?
993 · 911 · STI · S4 · rally car
Old 04-11-2005, 06:56 AM
Warped rotor, flat-spotted tire, bent wheel, failed shock seem like logical explanations. On the more dangerous/less-likely side: a bolt coming loose somewhere in the suspension, bad ball joint, bent A-arm, loose steering linkage, bad bearing.
Old 04-11-2005, 07:38 AM
IROC's Avatar
Unless the tires are new or nearly new, I would suspect the tires. They can be in balance, but wear patterns can cause vibrations. I had a set of fronts (A032s) that after many track miles *appeared* to be worn perfectly even and would balance just fine, but vibrated horribly.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-11-2005, 07:50 AM
I vote tire. I recently had a front tire develop a bubble that took a couple of days to find since it was on the inside of the tire. The shake was noticed at any speed. Thinking further back I had another tire separate belts or something to that effect that caused a slight shimmy.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 04-11-2005, 09:07 AM
