coloradoporsche's Avatar
Need help installing alternator
Hello,
After deciding that the squeaking from my 79SC engine was a bad alternator bearing, I decided to replace it with a rebuilt version which is all I can afford right now. Interestingly, I found that the alternator in the car was a rebuilt Marchal, not original equipment. Not sure how many miles it had on it.
Anyway, the "new" Rhone rebuilt alternator has less terminals than the old one:
My wiring before was as follows:
Terminal Wire
B+ .... Red wire with boot
+61 .... Blue wire with boot
D- .... Fat black wire
second D- .... 3 red wires
DF .... Thin black w/ quick connect
I'm not sure how to get these 5 wires on the new Rhone with only 3 terminals that have no markings on them at all.
The Rhone does have "Porsche" written on it with 911 603 120 04 J so I'm hoping it is compatible.
Can anybody help?
Thanks!
Old 04-12-2005, 08:38 AM
My assumption is, your "new" alternator has an internal regulator as opposed to the external regulator used with your old alternator. Sorry, I can't tell you which wires get connected (or where), but you'll be eliminating your external voltage regulator and a couple of wires that attach to it. A search will probably give you the above information. You may also have to wire a resistor in parallel with the alternator light on the dash (one of the reasons I had my original rebuilt rather than "upgrade" to the newer style).
Jerry M
'78 SC
Old 04-12-2005, 08:51 AM
dweymer's Avatar
Here you go..from host.
I'll buy your old marchal..PM me with a price
Donnie
Currently Porsche-less.....
Old 04-12-2005, 08:59 AM
Take a look here, it should answer most of your questions:
Tech Article Pg1
Tech Article Pg2
Old 04-12-2005, 09:01 AM
Don beat me to it....
Thanks everyone.
I don't know what I would do without this board.
Martin
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 04-12-2005, 09:16 AM
Just be careful still....
The tech articles are correct ...as to which wire gets connected to which post....
I seem to recall, however, that some applications position the alternator in the fan shroud so that the 12 o'clock position ( as seen on the backside of the alternator per the Tech Bulletin) might be at 6 o'clock ...as installed. If so, don't fret....follow the wiring pin-outs of the tech article but note that the "clock" may be rotated 180 degrees...adjust your thinking accordingly.
If not...and it goes in as shown...well....good for you !!!
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-12-2005, 09:55 AM
