project 911's Avatar
Engine tin seal question
71 911T- I'm in the middle of a partial engine drop and have a question about the rubber seal that meets the engine tins to seal off the upper engine bay. Should the edge of the tins go between the two flaps of the seal, or does it just come up from below and contact them both together? Hope I explained that right...
I think they where sandwiched before, but I never knew if that was right.
Thanks for any help.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 04-15-2005, 11:05 AM
Friend of Warren
They don't sandwich. Tin just makes contact with the bottom of the seal.
Kurt V
Old 04-15-2005, 11:33 AM
Thanks Kurt,
That makes things easier.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 04-15-2005, 11:41 AM
jdowty3's Avatar
I'll say thanks to both of you. I will be putting my engine back in this weekend and a similar question had crossed my mind.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 04-15-2005, 11:55 AM
oh well, I sandwiched mine. I doubt it can hurt anything as long as it seals the top from the bottom.
Neil
'73 911S targa
Old 04-15-2005, 01:41 PM
I think you're right Neil. It made sense to me to sandwitch it since the rubber has the two flaps, but I damaged mine trying to get part of it over, and part under. Like you said, I guess as long as it seals, it shouldn't make much difference.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 04-15-2005, 03:16 PM
I'm told they come sandwiched from the factory.
Old 04-15-2005, 03:52 PM
Bird. It's the word...
Fishcop's Avatar
I sandwiched too....
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 04-15-2005, 05:14 PM
ditto. no hard info.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-15-2005, 05:18 PM
Decolliber's Avatar
I sandwiched mine. Why else would it be split?
John C
1988 911 Carrera coupe
2002 BMW 530
Old 04-15-2005, 07:40 PM
Supposed to be sandwiched.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-15-2005, 07:44 PM
I did it from a logic point.. whatever that means.
so you figure it's like a common knowledge thing?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-15-2005, 07:55 PM
Common sense thing.
Stephan
Stephan Wilkinson
Old 04-15-2005, 08:01 PM
[B]Supposed to be sandwiched.
Absolutely right.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-15-2005, 08:23 PM
