passenger window trouble
I can control from the driver side but no action from the passenger side. Switch is good, I checked it out. Any obvious trouble shooting suggestions?
Semper drive!
Wires between passenger side switch and the window motor?
Just my WAG (Wild-Ass Guess) Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten ![]() One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Bland
Is your switched connected to the wires properly? Both windows on my car were wired up wrong when I bought it so neither would roll down and upon trying, it would blow the fuse...
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Designer King
Did you check the fuse/box? The 2 windows are separately fused.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
You say it could be the fuse even tho' the switch on the drivers side operates the pass. window fine? I will check it out
Fd |
look at the wiring diagrams on this board. They should help you find the problem. I just built a working wiring harness for my car for the power windows from the diagrams. There are two early car and later (post 1978 or so)
1971 RSR - interpretation |
sorry, kinda stealing thread but i also have a question about my passenger side power window.my pass side window has trouble rolling down (power windows) from both switches used to control that window. it is even worse when the window is wet, however if i open the pass side door and try to roll it down, it works perfectly. I havent pulled off the door card to inspect, any suggestions on what could be causing the problem?
-Riley .:1987 911 Carrera:. - Receiving Much Needed Love In Summer 2011 .:1993 BMW 325is:. - RIP Feb 2011 Last edited by Jon3sy; 04-17-2005 at 11:29 PM.. |
Heck, I’m only 5 not 71!
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
