passenger window trouble
I can control from the driver side but no action from the passenger side. Switch is good, I checked it out. Any obvious trouble shooting suggestions?
Old 04-15-2005, 10:41 AM
Semper drive!
rcecale's Avatar
Wires between passenger side switch and the window motor?
Just my WAG (Wild-Ass Guess)
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 04-15-2005, 10:51 AM
Bland
unclebilly's Avatar
Is your switched connected to the wires properly? Both windows on my car were wired up wrong when I bought it so neither would roll down and upon trying, it would blow the fuse...
Old 04-15-2005, 11:18 AM
Designer King
Paulporsche's Avatar
Did you check the fuse/box? The 2 windows are separately fused.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-15-2005, 12:12 PM
You say it could be the fuse even tho' the switch on the drivers side operates the pass. window fine? I will check it out
Fd
Old 04-17-2005, 04:41 PM
DW SD's Avatar
look at the wiring diagrams on this board. They should help you find the problem. I just built a working wiring harness for my car for the power windows from the diagrams. There are two early car and later (post 1978 or so)
1971 RSR - interpretation
Old 04-17-2005, 11:02 PM
Jon3sy's Avatar
Send a message via AIM to Jon3sy
sorry, kinda stealing thread but i also have a question about my passenger side power window.my pass side window has trouble rolling down (power windows) from both switches used to control that window. it is even worse when the window is wet, however if i open the pass side door and try to roll it down, it works perfectly. I havent pulled off the door card to inspect, any suggestions on what could be causing the problem?
-Riley
.:1987 911 Carrera:. - Receiving Much Needed Love In Summer 2011
.:1993 BMW 325is:. - RIP Feb 2011
Old 04-17-2005, 11:13 PM
Heck, I’m only 5 not 71!
targa80's Avatar
This sounds like your door is closing to tight and moving the window frame outwards causing it to bind when closed.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 04-18-2005, 03:27 AM
