I'd be careful trying to balance out an aero issue (high speed push) with the suspension. Since suspension changes generally affect all speed ranges, you might wind up with a car that is low speed loose and high speed neutral. You need to trim aero grip with aero changes and mechanical grip with mechanical changes -- otherwise the balance of the car will be screwed up.
If your aero package has caused you to pick up a push, add front downforce. Front downforce is generally pretty easy to find since you're dealing with clean air as it comes in contact with the car. It generally seems that improving rear end downforce (without adding a lot of drag) while working in the wake of the cabin is the more common challenge. Why not try extending (or adding) a front splitter? Maybe something in the vein of this for example...
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 04-16-2005 at 03:01 AM.. |
I am getting a kick out of this, I do hope it all does work, but Jack is the guy that didn't want a front cooler because the cooler snout would ruin the early cars pure looks
Jack a wind tunnel would be nice to have when your at speed. could there be a wind measure device like used in weather station mounted on the underside of the car to measure wind speed with various combinations of diffuser and wing?.This sounds crazy but you could get real time data.
Tailwagger NER/NCR PCA, SCCA, NASA, COM 2000 996 C2 Aero Brumos 59 Special Ed. 1970 911 3.2L RSR |
Administrator
I could spend a lot of time testing these pieces on the track, but there are so many variables. I think the better next step is to put together a way to monitor the ride height changes in front and back, and then use wool tufts and video to see where adjustments should be made. The ride height measurement is really the key, IMO. Whether its strain gauges, slide potentiometers, sonar or laser distance measurement, I need a long stretch of flat pavement and a way to produce data my DL-1 logger will be able to process.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I definitely think that is the way to go -- it'll be a lot easier to do this today with digital cameras than when the factory had guys stand out on autobahn overpasses to look at the wool tufts as the car went by.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
DP935 member
I found this aerodynamic wind tunnel simulator if anyone is interested.
I havent tried it and have no affiliations. http://www.kineticart.co.uk/WindStudioSimulator.asp
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
That is not a flow simulation program, its software for controlling and recording data from a real wind tunnel.
Or maybe stick a carpenters laser tape measure on the side of the fender pointing at the ground and run a camera to record it. I don't know if those things will take a reading while you're moving though. |
Your work is excellent. By seeing what is on the track and what you have, it looks good. Look at Yellowbird's post-hmmm
. Question: it seems that tire selection was not optimized?Regards,
Bernard |
Jack here are some pics. for the F430 underbodie and some wind tunnel pics. for the 360 CGT
the F430 have more downforce w/o spioler wing than the F360 GTC
X/A |
Administrator
Yellowbird, thanks! Some of the file names you gave the images were too long, causing the images not to display. I think I fixed them.
