RS carpet install HELP needed!!!
In my 87, I have the whole kit in except the kick panels and the area under the dash. I have these pieces left. I think #1 and 2 cover the removeable plastic kick panels. But I can't figure out 3 and 4 or their orientation. Where do they go and how? If you can tell me where and give me how far to rotate it clockwise, that would be a huge help. Please no guesses.
And yes I have searched, read, and checked the instructions on the Rallystuff sight, and Bob Tilton's sight, but I think the 87 kit has more pieces. ![]()
...sick with gearheadia Last edited by sushinav; 04-17-2005 at 09:41 AM.. |
All I hear are crickets chirping on this thread. Someone please help!
...sick with gearheadia |
Nobody
i have been playing tetris in my head for 3 and 4 and cannot figure it out. process of elimination - what has been installed? how about the rear passenger area (calf area for person sitting) or rear wheel well area?
I suffered throught he same dilemma. I contacted the mftr
http://appbiz.com/ and they sent me a worksheet key which sorted out the pieces and installation order. I looked for it but probably tossed it some time ago. One hint. The package shelf has lots of dips and bumps which make it difficult to attach the carpet. I went to home depot bought some thin carpet padding, I put it down first and then attached the carpet. Came out nice.
86 Carrera #178 |
Nobody
just thought of something - my kick panel pieces had vinyl trim for the door edge. my set was from OFI. i see that your pieces do not. personally i think basic instructions should be included with the kits even if it's a crude photo copied drawing.
Hey guys,
Thanx for ringing in again, Bob. You plugged my Corbeau seats when I sold them. Seems we have similar tastes. I'll call Bob at Appbiz and I'm sure he can clear this up. But the differences between years are apparently significant. I'll critique the lack of instructions too. Tetris...great analogy. I've been doing the same with the cutouts and notches in those pieces and every way in my car, still can't get it. All that is left is from the sills forward. So it has to be the kick panels and the footwell areas, just can't make em fit. I'm prepared for a big "aha" when I call Bob tomorrow. Stby for more...
1 and 2 are for covering the panels that your aux blower motors are behind. The ones just in front of your doors in the footwell. THe rear kick panels are not recovered, they are replaced by carpet. Those pieces have a small seam in them where they bend and change shape. I will go out and look at mine in the morning....
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Those do not match the shape of any of the carpet pieces in my RS kit... that said, the two pieces that cover the sides of the footwell were the hardest ones to install, involving a lot of cutting and tucking. They were a real pain, enough so that the passenger side one isn't even installed yet two years later.
To some extent you need to just keep moving them around until you find the position that everything fits in.
1968 911L 2004 Dodge Dakota SLT Plus |
Not a RS kit but maybe it will help.
Rob, 88 911 Turbo |
Check out this site. It may help:
http://www.rallystuff.com/pcar_carpet.html
'06 Cayman S '16 Cayenne '08 Audi RS 4 |
Even Bob at Appbiz didn't know. Anyone out there put a kit in a G50 car? HELP!
Hal, been there, done that.
Man, I wish I could help. My 71 Targa was didnt have any pieces that looked like that. They look like they should have been some of the first pieces installed as I dont see any trim on the edges, so I would think some other piece would cover those edges during install. Front kick panels are a good guess though.
Dan Byers |
Help...
Driving member
The best way to do this is remove each piece of old carpet
carefully and match them up with the new pieces. Some pieces may not look exactly alike but you should be able to find a piece to cover it all. I did this last year and it took me close to an hour to figure out the whole thing before I started installing anything. I can't remember the placement of the pieces in the pics. sorry
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
The original carpet left back in October before I stripped the sound deadening, then sent it to the paint shop. I had counted on at least some sort of instructions to come with the kit, and not as significant a differences between the Rallystuff directions and my kit. No luck.
Anyone ever figure this out! I now find myself struggling with the very same pieces
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
I received yesterday my RS carpet kit, and I have the same problem ![]() thank you. Alex. ![]() |
AutoBahned
search on carpet + diagram
swear I've seen one posed before - not sure if applicable to your situation |
Well, when looking at the pic that Install425 posted in post #9.
- Piece #IV goes on the driver's side....it is in the lower left corner of the pic by the piece that has slits in it for the brake/clutch pedals......and - Piece #III goes on the passenger side...it is in the upper left corner of the pic.... - Pieces I an II go in the middle under the dash....they are in the middle on the far left side of the pic |
Happiest when Tinkering
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Thread Tools | |
Rate This Thread | |
