where is the low side line to charge a/c
which fittin gon the compressor is the low side to add freon. the hose one the very top or on the side? anybody know
(factory a/c comp in 87 targa)
Jason Gautney 87 3.2 coupe |
Get a mirror and look at it from behind, it should say L=Low and H=High or S=Supply and R=Return. You want the LOW PRESSURE connector - before it compresses, which means L or R. If any doubts DON'T.
I assume you are adding R-12 to an OEM system. High side is the one going to condenser (deck lid). Low side is the one coming from the front of the car (evaporator). Deck lid should be down (almost closed) when adding refrigerant. If this makes no sense to you, get additional assistance. Wear safety goggles.
The low side is the line that is larger in diameter,it should be the line that comes down the passenger side of the car coming from the evaporator.If you have a engine lid condensor you will notice that one of the lines from the compressor goes to the condensor that's the high side.Good luck.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Senior Member
If you do not know which one is the low side of the compressor are you really sure you should be doing this type of maintenance? I know of people who have had their hand blown off by doing exactly what you are trying and got it wrong.
If you have not been trained at how to do this, and by a professional, please let a professional to it! Nothing against you but this can mame or kill you if not done totally correct. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
thanks guys, i will look at it, and if unsure i will take it to a shop
thanks again
I believe you may also see S (suction) and D (disharge)
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I agree with Joeaksa if you never work with a/c systems before and don't know the difference between the low side from the high side, connecting a can of freon to the high side could cause the can to explode (low side pressure is only about 45 psi whereas high side pressure could be over 200 psi). Have someone who knows something about a/c system help you or take it to a pro.
