rebuilt altenator noise
I just put in a rebuilt alternator pretty easy except I now get this funky noise from the alternator. Took off belt no noise so not timing chains. Spin's easy by hand I wonder if alternator is crappy ? Also if I lower idle down to 700 r.p.m.'s noise goes away.
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 04-18-2005, 04:32 PM
Bill Douglas's Avatar
How about trying it with the belt not quite so tight and see how that sounds?
Old 04-18-2005, 04:41 PM
belt is loose 1 shim on the inside.
1986 blk 930
2000 expedition
Old 04-18-2005, 04:53 PM
My alternator made a noise after I adjusted it to the correct spec's so I slackened it off so te belt had a lot of wobble, but not so much that it would flap around or slip, and this fixed the noise.
Old 04-19-2005, 02:30 PM
Registered abUser
TerryH's Avatar
If the alt was rebuilt locally, I would drive over and let them hear the problem. Then drive it for a week or two and see if it quiets down unless they suggest otherwise.
I've got my alt out getting rebuilt as we speak. Knocking on wood!!
'81 911SC Coupe SOLD
Old 04-19-2005, 03:10 PM
I always use a truck or marine rebuilder. They have to use quality bearings. If you were looking for a cheap rebuild you should figure 1in8 rebuilt starters and alt's are one foot in the grave and the other on a banana peel.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-19-2005, 03:15 PM
The rebuilder is taking it back no questions asked and giving me a new one.
1986 blk 930
2000 expedition
Old 04-20-2005, 03:52 AM
