Cliff, quit screwing around with your mixture already. Didn't you tell me you had a shop dial it in for you? Replace the accumulator and filter. I'll even make you a deal. I have a brand new accum and filter that you can swap in. If they fix the problem, buy them from me. If not, I'll take them back. You can't lose! Call me on my cell.
Broke
Yeah, Cliff, what Chris said!! That way you won't steal my parts!!
Beer is proof that God loves us and wants us to be happy. B. Franklin 93 968 Cab 81 SC Targa (Princess) Now Residing in Denmark 1973 RS Z28 Vash will never own it! |
this thing is making me mental.
i agree, mixture is best done by someone with the tools. i took my car to a mechanic, and he helped me check everything. freq valve, aav.... my mix was lean, and my timing was off. believe me, it runs tons better. but again, when the car is parked steeping in it's heat, (approx 45 mins) when it starts, it starts immediately., but chugs along. i got voltage at the WUR, but when i took it off to take a look i noticed someone in the past had dropped it. there is a dent at one of the screw heads. and i only have 9ohms at the connection. can a WUR be bad, when the pressures are decent? and any experience with rebuilt WUR's. still trouble shooting, but wondering, just in case. thank guys cliff. p.s. due to my extended vacation, i estimated the fuel to be 6-7 weeks old, so i took it out and added fresh stuff, from chevron.
poof! gone |
I think it is your accumulator. 22 psi is too low. The pressure should stay close to your warm control pressure for about 20 minutes. Probst says 3 bar for 20 minutes(44 psi). I know my old Mercedes would hold 40 psi forever. Good Luck.
69 911 2.3Ez 85 928S |
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
mitchell, i checked and me and chris have different part numbers on the accumulator. i would have.
poof! gone |
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Who is John Galt?
Intake leak! If your control pressures check out, then you're running lean because of a leak. It runs better cold because it's overly rich when cold.
'79 911sc Targa '02 slk230 kompressor '84 Tamiya Falcon A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years. |
thanks stoney. and everyone else. back at it this morning. I SHALL PREVAIL!
poof! gone |
Just fixed a similar problem.... chased all the miscellaneous things, did all the CIS pressure test and it ended up being damn air leak in the big boot on the top of the throttle body. Those damn vacuum leaks with kill you. Anyway, problem fixed now and happy motoring.
Good luck...I understand your frustration. Chris
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
Popping through intake to lean. Popping through exhaust to rich
1981SC |
Cliff-
You need any help? Sitting here looking at the rain and trying to figure out ways to procrastinate on painting a bathroom and hallway. I am sooooo sick of f---ing house projects!!! PM me if you want to stop by. -Jon |
Vash (or is it Cliff?),
The next time you have the problem, remove the air filter, reach in and raise the air flow sensor plate breifly, like 3-4 seconds. You should hear a sort of whine from the injectors spraying. Not too long or you can flood the engine. Then crank the engine and see if the problem has improved. Sounds to me like bubbles in the gas in the injector lines could be the problem. Worth a shot, and it's cheap. Your residual pressures seem to be in spec, but this might not tell the whole story.
Jim www.jimsbasementworkshop.com (CIS Primer for the 911) (73 911T (RS look) coupe) (Misc. 911 Parts for Sale) |
Unregistered
Yelcab1, I think what was meant is that if it is running very lean and you pull the cap, it could cause the engine to stop running due to extremely lean condition. The extra air would prolly push it over the edge.
Obviously if it is adjusted to spec it will continue to run but will stumble a bit. If it is idling too rich, opening the cap and allowing in un-metered air might actually help the idle a bit. |
ok, i am effen taking a break.
car runs fine, but still upon startup warm, after sitting for a bit, the idle will stumble around @ 500 rpm. schit doesnt happen when there is a mechanic around. adjusted timing, mix. WUR ohms went huge warm, (thinking about this some more, it shouldnt matter, car is hot anyways), and big dent in it, made me change it out. new acumulator, and since i was there, new filter. fresh gas. found crack vacumn line to WUR and replaced it. had a new oil cap gasket around, so i put it in. freq valve checked. looked for vacumn leaks at injectors, none. *****, the list goes on. gonna flashlight the AAV manana. showered, garaged closed, i am gonna eat out, drink some and hang with the girlfriend. i think she understands CIS now, i talk about it so much. cliff
poof! gone |
Scott Clevenger 1989 BMW 325ix 190K 1981 911SC 110K miles http://www.pelicanparts.com/gallery/clevy70911T/ |
scott, i think high idle is easier than low idle. good luck
edit: AAV is AAVing perfectly. NEXT!
poof! gone Last edited by vash; 04-24-2005 at 08:03 AM.. |
Cliff,
Did you ever try my suggestion to briefly lift up on the air flow sensor before you try the start, in a situation where you think you are going to have the warm start problem?
Thread Tools | |
Rate This Thread | |
