3.6 conversion
I have a question about a hose that connects to the distributor.
Last week end this 'bout 3/8" hose literally hit the fan. So, I cut it out. There's no damage. My question is should this hose be plugged? The car doesn't run any diff. w/out it plugged. Gary
1985 911 Carerra Cab 3.6l 1998 Dodge Ram 2004 Toyota Tundra Quad Cab |
gduke, the hose is there for a reason!! It vents the distributor housing, to prevent secondary distributor drive belt breakage.Put it back!! Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Senior Member
Porsche does very little on their cars that is not very important. As Dan mentioned, its part of a kit that was added when the secondary dizzy started breaking its drive belt, so needs to be repaired.
It normally plugs onto a heading air duct to get its air. Assume that you pulled this off? JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I plugged it back in but only have 6" of hose. Will this be OK? I could get more of this hose from a hardware store.
Not sure what a heading air duct is?
Hilbilly Deluxe
He meant heating.
Tom |
Administrator
Inside the spark-filled distributor, the ozone that's produced eats away at the rubber belt that links the two distributor rotors. Pumping fresh air in from the heater duct prevents the belt from breaking down and snapping. This, in turn, could save your engine (if the belt snapped and one of the rotors stopped in the 'always firing' position).
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Like everyone else said the dist. needs to vent. Here is a pic of what it should look like
![]() Ignore the O2 sensor connection in the foreground it's just there as convenience in that pic
Thanks for your replies. I'm sure they'll prevent major damage. It's great that we have this mess. board.
Gary
Took a trip to the hardware store bought some hose and a fitting which I tapped into the heat bypass tube. It took about 10 min. to complete the project and cost less than $5.00 and prob. saved me $thousands.
Would not have known w/out replies to my question. Once again, thanks. Gary
It looks just like Bill V's, except for the carbon tube which will be added next spring. Spent too much $$ this spring, had to draw the line on upgrades somewhere.
