Dansk doesn't seem to fit...
What am I missing here. I am trying to install a 1 in 2 out dansk on my 86 coupe. The valence is removed. I have tried to line up the intake with my cat bypass pipe but the driver's side muffler pipe bumps up against the lower bumper. Has anyone had this problem???
Air Medal or two
I cant see enough of it...dose the other part need to be loosened and slid a head??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
maybe you need a spacer there?
Banned
I agree with afterburn, take four or five more pics from below and looking back the opposite direction and post them.
Here are some more pics...
Doesn't want/need a 3.6L
Well from the pics shown, it looks like the muffler needs to be rotated upward, as the tips are way too low, even with the valance removed.
I had a 1-in 2-out Dansk just like yours previously when my motor was a 3.2L, and it fit fine. Others haven't apparently been so fortunate. I now have the same basic muffler, except it is now a 2-in and 2-out because I am using headers. This muffler also fits fine. Ralph |
Ralph,
What I am noticing is that the lower bumper is wrapped around toward the rear of the car more on the left than the right, creating the clearance problem. The right side sits fine. Is your lower bumper situated this way? The muffler looks like it is turned down because it is just sitting on jackstands and tends to rotate down with the weight of the pipes when I'm not holding it. |
Thanks for clarifying regarding the jackstands/tip orientation, I couldn't figure out how the tips could sit that low! Here are a couple of pics of mine when the motor was a 3.2L and used the 1-in 2-out muffler: and a close-up of the left side tip: Hope that helps a bit! Ralph |
here's my dansk.
my passenger side was about 1inch lower than the driver's side. returned and exchanged 3x. all did the same. finally, had to cut, turn and weld to get it to fit. good luck. aw |
O.K., finally got the bugger on. I loosened up the nuts connecting the bypass pipe and then tightened everything together. Fired it up and it sounds awesome! Not ricer like, but kinda throaty. It also looks better than I thought without the rear valence. Now if I can just get the OEM straps to fit...
Thanks for all the help tonight. Does every marque have a forum like this??? If not, they're missing out. -Jeff p.s. Hey AW, how did you get your bumperettes off? That was part two of this project, but they are glued on there good. I'm afraid to rip at them too hard. Any advice? |
Banned
Banned
Bye, Bye.
And I was going to post that I thought you had the wrong muffler, then I see that you got it on. Anyway, if this question comes up in the future, keep in mind that the 3.2 muffler is different than an SC muffler, in that the 3.2 has an indention to accommodate a bypass (edit: crossover) pipe, where the SC does not. I found this out the hard way...so read and benefit from my mistake.
I am glad it worked out, the dual out Dansk on a 3.2 sounds great.
Elvis has left the building. Last edited by Scooter; 04-22-2005 at 03:58 PM.. |
Light,Nimble,Uncivilized
FWIW my passenger side outlet pipe also hangs ~.5 inches lower than the drivers side.
Drago '69 Coupe R #464 |
I had posted earlier on the installation of a 1 in, 2 out Fabspeed. I recommended exactly what you did for fitment. Good job, BTW!
Always, when installing aftermarket headers, SSI, pre-muffler, sport mufflers, its a good idea to loosen items within the chain and tighten in increments for quality of fitment. Now turn down the radio, and enjoy the real music. Cheers.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Limbo
Jeff,
To get the bumperettes off, you sometimes have to put the nuts back on (not all the way) and hit then with a hammer in order to loosen the bumperettes from the bumper. They do seem like they are glued on but they are not.
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
Banned
Is that the Dansk pre-muffler I see on your car in that photo? This thread has been very informative, by the way.
Yep, that was the Dansk stainless pre-muffler I used to run. Sold to a local Pelicanite. Ralph |
hey jeff, hit them with a rubber mallet. also helps to remove the rear valence first. aw
Where did you get the muffler? What is the P/N? The earlier version did not have the relief for the heater cross over pipe. Don't ask how I know, but I think I've seen this before.
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
